OC-Master said:
A little secret for those of you interested,,, The barriar to 32-bit computing from a single processor is 4GB of memory. By going 64-bit or allowing for multi processing, one can venture behond 4GB to 8GB with the dually processors or 16GB of ram on a Single 64-bit platform.
Just think, Dual Athlon-64s could support 32GB of ram on one motherboard.
OC-Master
Medicated said:
actually, i'm pretty sure a 64 bit proc would be able to support far more than 16GB, the limit is the number of addressable memory locations, 32 bit addressing = 2^32(4294967296) unique memory addresses = 4GB
64 bit addressing = 2^64(18446744073709551616) = 18 exabytes(think thats the correct prefix) which is a whole hell of a lot more than 16GB
DaBigJ said:You can turn off the swap file in WinXP, but there's still a "phantom" swap file that exists somehow. If you use the task manager (ctrl-alt-del), it shows how much page file windows is using. Very very strange....
OC-Master said:Come to think of it, if I had the chance to get more ram, I would. But unfortuneatly, my motherboard only supports up to 1.5GB of ram.
The Athlon-64 motherboards can handle up to 16GBytes of ram so we should see my next PC with at least 4GB of ram to start with and hopefully 8GB of ram by 2006.
OC-Master
Lithan said:Theres a reg command to force windows to only use a swapfile when physical memory is full. Damned if I remember it. But it's there.
KerryrreK said:what operating system do you have? And why exactly do you need this much RAM? What do you do with it?
Kerry
OC-Master said:
But as you can tell from 3Dmark2001SE, the score not only stayed flat but gained additional points overall.
OC-Master
