- Apr 9, 2002
- NH
Hello,
I feel stupid asking you folks this but I'm confused and you guys know the answers so quickly.
Anyway, I want to buy a peltier unit to plug into one of my molex connectors for my power supply. My power supply is an Ultra X-connect 500 watt power supply. Here's the link to it:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=874746&CatId=1079
Now I want to buy the biggest peltier unit I can use to attach to the molex on the power supply (the thing that you plug into the hard drive). So I was looking on ebay and came across this wicked deal:
1pc 12706 Thermoelectric Cooler Peltier Plate 60W for $5.00!
TEC1-12706 60W TEC Thermoelectric Cooler Cooling Peltier Plate
So I was going to take that plate and attach the two wires to the molex (not sure which ones go where but there's only two so maybe I got a shot at it). Then I have a case fan that I can put underneath the peltier to cool the heat that will come off of it. So I will have a wicked powerful cooling unit to keep my drinks chilled!
So I was wondering can I go up in wattage? I did a search online for a volt to watt converter. 12 volts equals 12 watts. So maybe the most I can go is with a 12 watt peltier? Is there a way I can give this more juice? Would 12 watts be a pretty cool cooler? I have one running off my usb port right now (which I think is 5.0 volts / 5 watts). It's kinda cool but I want it cooler.
Oh, if I hooked the molex to a peltier that needs less watts will I kill anything? Do they have to be exact (i.e. 12 volt peltier and 12 volt rail?). This electronics stuff is cool but confusing....
