- Jun 19, 2003
- Canada, Ottawa/Toronto
I put together a small loop with a swiftech 2x120 rad, mcp655 pump, swiftech gtz ci7. It goes pump > rad > T-line > CPU > pump. I decided to use some cheap 1/2" id, 3/4" od tubing from the local hardware store, but it's so stiff i can't bend it to fit in my case. Anything tighter than a 4" radius bend takes a lot of forcing. Is brand name tubing any better? It's hard for me to get decent tubing since I'm in Canada. I'm almost thinking of just sticking in a bunch of 'L' bends, but i'd rather not because i'm sure they'll restrict the flow by a lot.
Any suggestions?
Any suggestions?
