Hold my taco, I got this!
What settings do we run it in? Just whatever is up when you run it? Do i start at default settings and hit "F9" to nenchmark?
I know ;( NOOB question
The render test helps the bench score right.
You might be able to just disable the driver in task manager then you won't need to pull out the card.
Did a little curiosity test, looks like the difference between Win10 and Win7 is negligible.
Johan45/ RX580/ AIR/ 3292.635
Win10/ 3286.178
If anyone has problems with this benchmark then try 'typical' installation file, ignore cpu-z, set your region/language in Windows as English UK or US and be sure that there is no font installation error during the installation. If you have any non-English OS then benchmark will crash if you don't change your OS region settings.
It works fine on Win7, 8, 10 and server series.
I had up to 400 points better scores on Win7 on new nvidia cards like GTX1080Ti or RTX2060. I guess it depends on gpu series and drivers but if anyone has 2 OS then can check.
I will add something on Vega56 when I play some more with this card. Made quick run yesterday but forgot to save. Was 5100 or something. Will try to beat ED 2080Ti score
Sir MaddMutt, did you forget to include a screenshot? Only score in your post
I have a 9800gt
I'm still at it I must like being the underdog
You're leading from the other side, Sir!
