- Thread Starter
- #21
again.
Thank you for your answer but with all due respect, how this info will help you fix my problem ?
again.
Boost clocks are probably higher too (assuming its a faster bios). The boost tables and such change as well. Ive flashed plenty (ok, 3) nvidia gpus with a faster bios and each raised the actual/live boost clocks from the previous bios.Also pascal cards are auto overclocking. Reflashing to an OC version only changes the BASE clocks. Your running clocks are probably identical if you haven’t applied any offsets and aren’t hitting thermal throttling.
'Auto overclocking' = boost.
I think this is only the case for the 1070.. gtx 1080 has only GDDR5X Micron Memory.
I am still stuck with that issue. It seems like the gpu memory clock is stuck at p8 state : 405 MHz (however, core clock is working fine).. and can never rampup above that value.
Does it mean the gpu memory is faulty ? Is there a way to fix that ?
FYI problem is solved. Bios to be used in my case is 86.04.60.00.BF : https://www.techpowerup.com/vgabios/197719/197719.
