- Oct 18, 2002
- Los Angeles
- Thread Starter
- #61
Just ran 3dmark again and I got 18426 marks and I rank number 1654 out of all systems test... if only I knew how to properly submit the results with a linkable page
Yeah, I've decided to do this mod... I just have to get my ohm sensor here.... and I'll stick in the MX2 paste that I bought and post up the results.
Can I get a full 100ohms with a #2 pencil or will I need to go out and buy some sort of kit to get the full 100 ohms?
what is that vcore mod though? is it just to increase the max vcore?
Do I need to do both these mods for the correct vdroop fix?
Ok, apparently I'm supposed to add 100 ohms, I did the mod and am now getting 1.5 volts in the bios sense when I set it at 1.5
There's one problem, the motherboard seems to up the voltage when the cpu's are being stressed... so it's a reverse droop...
Right now I have it set at 1.487 in bios and its showing up as 1.488 in cpuz running stock but as soon as I stress the cores, the voltage upps to 1.496, a difference of .008
