Hi Just need some help. I've gotten tired of higher temps, noise, and dust so I'm going to visit Atlantis.
Specs:
2500k @ 4.3ghz and 1.32vocre 68-73 load IBT.
gigabyte p67a-ud4-b3
kingston hyperx 1600 8gb
560 ti evga fpb (soon 7950 w/ waterblock)
wd caviar raid 2x320 , hitachi deskstar 1tb, pat. inferno 100gb sata 3
ultra 850w
raven 3
hyper 212+ w/ 2x blademaster
9 other case fans (3 orig. plus others, irrelevant I guess).
I want to buy this kit, http://www.ebay.com/itm/XSPC-Raysto...37647?pt=US_Water_Cooling&hash=item4167ac944f
and probably add another rad such as this http://www.ebay.com/itm/EKWB-EK-Coo...89643?pt=US_Water_Cooling&hash=item3a7502528b.
I'll be getting an ek full block for the 7950, and I obv. have enough fans for all the rads already biggrin.gif.
I'm not sensitive to noise, seeing as I have most of the 11 fans running full volt when-ever I have my comp but, (call me a ***** if you want tongue.gif) hearing the quiet sound of a pump and nothing else can be peaceful and calming (and hell for all the nubs tongue.gif).
I made this in paint, I don't really know how to draw the hoses in but this is my planned rad setup, (attached).
Not doing the outside rad, will change it but I've just been here and there (4 wisdom teeth pulled monday so yea. kinda :/ atm).
Let's call the 240mm rad code 1, and 280mm code 2.
My hose setup starting with the two tube holes made for the raven 3 would 1->cpu->2->gpu. This would be a gentle curving loop and I think I'm probably just going to have the res and pump outside the computer. I havn't seen the hw yet, so idk but I could just take it to the side of the case. :/ Idk of a way to fit it in the case but just over the 280mm rad would be most likely since there's a lot of room there to the right of the gpu.
Any suggestions, welcomes, ideas etc.?
I'll probably just get pt_nuke or use a few drops of bleach for anti-bacterial and since no alum. no need for anti-corrosive.
Anyway, under the waves we go.
edit - I added an updated photo with my hose layout orange being the second possible exit route.
edit - tl;dr getting sh*t done new layout uploaded.
Specs:
ultra 850w
raven 3
