As you may have guessed, I am about to drop some of my cash, on a new build, to replace my rapidly dying desktop. Cost is an important feature to me, and have around £800, £900 on a strech to spend on this, which I am trying to make last as long as possible.
So, the list of components, along with what I've been thinking about:
Intel Core 2 Quad Q6600 OEM / Retail (undecided on which version. What about a Q8300, just if the L2 Cache is a big problem, and overclockability)
Scythe Ninja II with 120mm Fan for cooling.
Gigabyte GA-EP45-DS3 Motherboard.
4GB (2x 2GB) Corsair DDR2 800MHz Memory
512MB Sapphire HD4850 Graphics
520W Coolermaster Modular PSU
2x 500GB Western Digital Caviar Green 16MB drives, or 2x 500GB Seagate Barracuda drives, depending on which is cheaper at Scan.co.uk on ordering (running in RAID 0 or RAID 1 not decided)
19" monitor to go dual with my current 19".
Vista Home Premium SP1 (having Vista over XP, definitley).
Wireless PCI Card, Optical Drive and cooling fans are also in the basket and using current case, takes price to £825. I'm not to sure on motherboard, as the one I wanted just got discontinues (the DS3R). I do like the look of the iP45 based Asus boards, but, the power placement isn't really placed very well. So ideas? Oh, and it must come from Scan.co.uk (parent's only like the one place ordering idea)
Thanks for any advice etc,
Adam
Adam
