New Koolance 800D Water Cooled Rig
Here is my (Updated) Spec:
Case - Corsair Obsidian 800D Tower Case
PSU - SilverStone ST1500 Power Supply, 1500w, Black
Motherboard - ASUS RAMPAGE-III-EXTREME Motherboard, LGA1366, X58, 6xDDR3-1066, 4xPCI-Ex16 v2.0, 2xSATA-III, 6xSATA-II, RAID, GigLAN, 8Chl-HD, USB3.0, ATX
Motherboard WB - Koolance MB-ASR3E (ASUS Rampage III Extreme)
CPU - Intel Core i7 980X Extreme Edition
CPU WB - Koolance CPU-360
RAM - Corsair 6GB (3 x 2GB) DOMINATOR GT - PC3 16000 (2000Mhz) DDR3 RAM - 240-pin DIMM - CL 8-9-8-24
Graphics Card - 2 x XFX Radeon HD 5970 Black Edition, 2GB 256-bit GDDR5, 725MHz GPU, 1000MHz Memory, PCI-E 2.0 x16, DX11, Dual DVI, HDCP, Mini DisplayPort, CrossFireX Ready + Koolance Dual VID Connector, Adjustable 1 Slot Spacing
SSD - 2 x Corsair Force Series 120GB 2.5" SATA II MLC Solid State Drive - 285MB/s Read & 275MB/s Write
Tubing - Koolance, Blue UV Reactive PVC, ID: 13mm OD: 16mm + Tubing Spring Wraps - Koolance, Tubing Spring Wrap, Blue, 13mm
Fittings & Connectors - Splitter (Koolance Tubing Splitter/Manifold, 5-way Swiveling), Nozzles (Koolance Nozzle Single, 1/2" (13mm) G1/4 Threaded & Koolance Nozzle Single, G1/4 Swivel Angled [13mm, 1/2"] - Single Fitting), Quick Disconnects (Koolance QDC (High Flow) No-Spill Shutoff, Male Angle/Female, ID: 13mm) & Koolance Pressure Valve
Temp Sensors - 2 x Koolance Coolant Temperature Sensor Plugs
Fans - Cooler Master R4-L2S-12KB-G Silent120mm Case Fan w/ ON/OFF Switch w/ BLUE LED
Drive - Pioneer BDR-205BKRP Blu-Ray Writer - SATA, 12xBD-R, 2xBD-RE, 16xDVD±R, 6xDVD±RW, 8xDVD±R DL
Misc:
Koolance Liquid Coolant Bottle, 700mL Clear
Arctic Cooling MX-3 Ultra Premium Thermal Compound with High Thermal Conductivity for the GPU's
Indigo Xtreme for the CPU
Lighting - Logisys True-Color CCFL Light Bar - 12" - Blue
Arctic Silver Arctic Alumina Thermal Adhesive (Epoxy) for affixing the Temp Sensors
External Unit:
Lian Li Modified Case: PC-343B Modular Black Aluminum Cube Case
Magicool Nova 1080 (9 x 120mm Fans)
Waterjet cut radgrill and 9 x Cooler Master Silent 120mm Blue LED fans
2 x Koolance PMP-450S in parallel
Koolance - TMS-200 Software Thermal Interface Controller
Koolance - TMS-EB200 Expansion Board
Koolance - RP-450X2 Dual 5.25" Reservoir
Misc:
External Unit:
