- Dec 5, 2004
- Milwaukee, WI
- Thread Starter
- #41
while i was pulling parts out of my PC to prep it for WC, i had a crazy freakin idea to mount the floppy drive in the second PSU bracket above the motherboard... so i grabbed a sheet of 1/16" aluminum that i had, cut it out on the scroll saw, drilled a few holes, and bam! you have the sickest floppy drive relocation that i've ever seen ![Attention :attn: :attn:](/forums/oc_images/images/smilies/head_bang.gif)
got my 2 Alphacool Delrin Repack reservoirs mounted (sexy, eh?)
got my 2 DDC-2 pumps mounted to run in series - i have a 12x12" sheet of 1/2" clear gel rubber coming from mcmaster (same stuff as petras tech "gel stuff") that i'm going to put behind/under the pumps to isolate vibration from the case
i also drilled out all the holes in the original hard drive rack, and added rubber grommets to it - i will actually be using this for the hard drives, and you'll see how its all going to work out once i get some 2" 6-32 threaded standoffs from mcmaster
... and i got my PA 120.3 w/ shouds mounted
last pic: this is my computer as it currently sits while i prep/mod my case for water cooling
![ill_40.jpg](http://mac-owner.com/sneaky/illuminati/ill_40.jpg)
![ill_41.jpg](http://mac-owner.com/sneaky/illuminati/ill_41.jpg)
![ill_42.jpg](http://mac-owner.com/sneaky/illuminati/ill_42.jpg)
![ill_43.jpg](http://mac-owner.com/sneaky/illuminati/ill_43.jpg)
![ill_44.jpg](http://mac-owner.com/sneaky/illuminati/ill_44.jpg)
![ill_45.jpg](http://mac-owner.com/sneaky/illuminati/ill_45.jpg)
![ill_49.jpg](http://mac-owner.com/sneaky/illuminati/ill_49.jpg)
![ill_46.jpg](http://mac-owner.com/sneaky/illuminati/ill_46.jpg)
![ill_47.jpg](http://mac-owner.com/sneaky/illuminati/ill_47.jpg)
