tried lowering the water level to allow more bubbles to stop at the top, but it just sucked more air in from the top of the water because 2 pumps = too strong of a suction i guess
the what i did last night when i just gave up, was put the reservoir pointing straight up, pulled off the acrylic front, topped it off til it hit the o-ring, and then re-attached the front, spilling any leftover water, and leaving ZERO air in the res
but now whatever air was in the loop just goes straight through the res and back to the pump inlet, and recirculates, you can see it right through the tubing, and you can definitely hear it
anyways, i ordered 2 mcres-micro's last night and have a decent plan for them (mounting and tubing wise)
and hainer, the only reason i didn't go with one like that is because i'm looking to keep each of the loops completely separate from eachother
and thoes alphacool cape coolplex reservoirs are nice looking, but aluminum end caps = no thanks!
