- Nov 16, 2007
Heyy, im new around here and new to overclocking and after reading this guide http://www.ocforums.com/showthread.php?t=515316 and a few other guides on the net it got me thinking about overclocking my machine to 3.0 Ghz.
SPECS:
EVGA E-GEFORCE 8600GTS 675MHZ 256MB 2.0GHZ GDDR3 PCI-E Dual DVI-I HDTV Out DIRECTX10 Video Card
Gigabyte GA-P35-DS3R ATX LGA775 Conroe P35 DDR2 1PCI-E16 3PCI-E1 SATA RAID Sound GBLAN Motherboard
Antec Sonata III Black ATX 16IN Quiet Case 3X5.25 2X3.5 4X3.5IN 500W 120MM Fan
Corsair XMS2 TWIN2X2048-6400 2GB 2X1GB PC2-6400 DDR2-800 CL 5-5-5-18 240PIN DIMM Dual Chan
Western Digital Caviar SE16 250GB SATA2 7200RPM 16MB 8.9MS Hard Drive 3 Year MFR Warranty
Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box
Extras for OVERCLOCK:
2 added Yate Loon D12SL-12 120MM Fan 1350RPM 47CFM 28DB 3PIN & 4PIN Sleeve Bearing OEM
Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM
i understand every build is different and can withstand different stresses, but i want you guys to kinda tell me what setting i should put to get to my 3.0 ghz and not damage my computer keeping in mind my specs above
And if possible let me know if you think i cant overclock it to 3.0 ghz and what you think a good speed to have it at is good, im also worried about what the guide said 1:1 ratio for the ram and something about lowering my video card speed in order for it not to burn out when i overclock my processor, can you please shed some light on what i should do to my ram and video card to get it at that ratio?
Thanks alot for the help
SPECS:
