Okay thanks! I have passed and am stable with a small fft for 3.5 hours. But if I fail in blend test do I raise the DRAM voltage or what steps do I take to correct a fail?
If you can pass 2 hours blend without issue in most cases you can throw anything at the Pc without an issue.I just left the blend at default so its only using about 45-50% of my RAM, but so far its been stable for 1.5 hours.
I like to raise it a bit, leaving a couple GB available so that the OS doesn't freak out. I blend with 6GB of RAM on my box with 8GB. It's probably not really necessary, but I figure I might as well increase the hardware footprint of the test a bit to make sure everything's really getting stressed.So is using just the blend test typically enough to check for stability? Or do I need to raise the RAM amount higher?
Some people will have different opinions and to let you know where I'm coming from I'll say this. I use my rig for work, gaming and just normal browsing. My work entails having 4 screens, with multiple windows open, news services and such. When things are busy, my rig is running at or near 100% for extended periods of time and if it crashed it could be very costly $$$$$$$ wise for me. I have also run F@H for 2 weeks 24/7 during the chimp challenge we used to do which also runs the Cpu @ 100%. If I can pass 2 hours of Prime Blend with my Oc I have yet to have an issue during my usage. In my book if you didn't have an issue until 3 hours you're stable.Alright so failed a blend test after 3 hours. Went to bios and raised CPU/nb voltage and raised the dram voltage. Trying again now. Should I mess with the CPU/nb frequency at all?
Why?Yes. And I would try at least 20 MB FFTs or around there.
Why?
Most people never budge past the default settings. Is there are reason you recommend this method over the default (which appears to work just fine?)?
If I can find a setting that allows blend to run all night with no errors should I call it good?
cjkart20, do yourself a favor and start taking notes of what you're doing it will help greatly when one loses their way.So some how I got all jacked up and can't even pass a blend test for 25 minutes now lol. Went back to defaults and am just increasing the CPU/nb voltage in addition to watching temps everytime I fail. If I can find a setting that allows blend to run all night with no errors should I call it good? Or should I then do a small fft to check CPU?
