- Oct 7, 2004
- Cincinnati
Did you make something similar to your RAM block to cool your mosfets?
Skeen said:Did you make something similar to your RAM block to cool your mosfets?
Skeen said:Please forgive me for my laziness, but what was the stuff you used to waterproof your board? I just read through both of your threads and don't really relish trying to pick through it.
Thanks
Susquehannock said:Oh yeah!! Love to see this DIY stuff.
> "Others may call it junk collecting ....
I call it recycling." <
Indeed! The Copper scraps they throw away at many construction sites can be
used to make all sorts of great stuff. Especially if you melt it down.![]()
Moto7451 said:Casting copper without a vacuum will result in very low grade copper.
Ven0m said:Really sick comp
About copper casting - if you decide for it, you ned at least partial vacuum process. Typical vacuum would be the best, but even then, don't expect to get good results with complicated shapes. Anyway, if you decide for casting micro block, silver is a great material. (and small amounts are pretty cheap)
BlueBall said:So silver is easier to melt down? I know its a great conductor of heat too.
How come I havn't seen silver plated HSFs and stuff? Is it the cost?
nickel is fairly bad as far as heat conduction goes:Brundle Fly said:I thought it was nickel that was a better heat conductor, hence the reason Thermalright uses a nickel coating on the base of the XP-120.
Very nice work by the way, I love the CPU block, looks very cool.![]()
Brundle Fly said:Hahahahaha, yeah, I saw a thread with that situation in it.
So, if nickel is not better than copper, what is the point of plating the base? I suppose it would solve the oxidation problem, it certainly can't be for aesthetics, it's not like the base can be seen once the sink is installed.![]()
ghettocomp said:I think they plate with nickel because it looks all nice an shiny at first. a cheap bling bling thing
Brundle Fly said:So, if nickel is not better than copper, what is the point of plating the base? I suppose it would solve the oxidation problem, it certainly can't be for aesthetics, it's not like the base can be seen once the sink is installed.
Skeen said:It does seem pretty silly considering:
1. Its the bottom of the heatsink (but ok its probably easier to do the whole base as opposed to just the top of the base).
2. That whole heatpipe/fin array is so damn big (plus a fan on top) that you probably don't see the base all that much anyway.
