- Aug 19, 2002
- Redmond, Washington
I am currently in the beginning stages of a major mod. It involves putting two motherboards in one case, the size of which was designed to be a tight fit for one. It will be quite a feat, and quite the spectacle when done. My question, though, is about RF interference. There will not be a metal plate between the two, so it would be two motherboards facing each other with no barrier what-so-ever between them. Will this cause a problem, or is an RF shield designed to block outside noice from bugging the inside, like a PC monitor and speakers? I sorta' need to know rapidly, too.
Thanks in advance
Z
Thanks in advance
Z
