- Thread Starter
- #41
This is the chipset that I have on this machine as I was having problems installing drivers...
http://support.intel.com/products/chipsets/845gl/index.htm
About 30 mins ago a buddy told me to change it to:
Initial: 2046
Maximum: 4092
Should I up either of them?
leave your page file for windows to handle, period
I always make it a fixed size both min and max being the same number, in his case 4092 and 4092. Fragmented page file can slow you system down big time.
Also check to see if Ultra DMA is enabled in BIOS. This is an older system and may have this turned off for compatibility.
And another thing Intel speed step and XP have a major issue with DELLS. There is a patch to fix this, not sure if your system is affected.
After doing some reading into your problem, I would look at your RAM or one of your RAM slots is bad. Try running a single stick of the older 512MB.
Run your system through your normal tasks... Maybe download Sisosft sandra and do some memory tests. Then shut down and move it to the other RAM slot. If all goes good, then move to a single 1 gig stick, repeat and rinse...lol
I'm banking on either a bad slot, or bad RAM. Remember, new RAM can come DOA...
Joeteck & madhatter256.....the problems seem to have remedied themselves.....all of my RAM seems to test out just fine and the machine is running much much faster.
When I was cleaning the dust out the chassis that holds down the heat sink broke and I need to replace the chassis. The manual doesnt provide a part #. Anyone know where I can find one of these? I know that its not safe to run the machine without it.....also...the gasket is shot....what do I replace that with?
