- Jan 18, 2010
- Calgary, Alberta, CANADA!
Still a very nice OC for sure.
NICE
How about with x4 AA ?
Muchos Gracias...
I wasn't expecting such a leap in FPS from the last time... altho last time my cpu was clocked at 4GHz and this time 4.2 but still... gone from 48 to 79?!?!
I'm working on 4xAA now... but it seems to crash, my overclock might not be stable... we shall see...
Why only 1150 Mhz for mem? I got my 5750 to 1265 stock. Do you get issues with pushing it higher?
Weird
Looks like AA isn't working right....can you see a diff in the benchmark run?
Yeah...GPU-Z under the sensors tab
Yeah...that's 2D voltage....check the box marked "Continue refreshing..."
then run the benchmark again, when it's finished, take another SS like that one and post it up
I think you're card may be throttling under heavy load with the extra voltage...
Very interesting thread, great work sandy!
The 5800 series GPUs are designed with 8xAA in mind, so much so that they are optimised for this more than 4x (hence why I asked you to do 8x instead of 4x ).
One way to see would be to disable Catalyst AI, that will turn crossfire off so you're running on one GPU, then the benchmark should be slow enough to see whether AA is working or not.
I bet that it is and that the card is just so fast the AA isn't the bottleneck anymore.
Remember how my 5870 held up in the test we did, it lost a lot less FPS than your 4870X2.
