Ok I fixed it.
I found a buch of stuff on the web and tryed these things:
1. Uninstall max.
2. Empty your 'c:\windows\temp directory' (make sure 'show hidden files' is on so you can select and delete _ALL_ the files in there).
3. Delete all the directories and files in the 'c:\program files\installshield installation information' directory (You'll need 'show hidden files' on to see this directory as it's marked hidden).
4. Reboot.
5. Reinstall max.
6. Play and/or repatch.
And then,...
make sure the following are checked: Disconnect, Sync Data Transfer, Auto Insert Notification. Make sure DMA is unchecked. On your CD-rom
And then,...(optional mine was already)
On the Device Manager tab, left click the plus (+) in front of the "Creative Miscellaneous Devices" line. Highlight the "Creative SB16 Emulation" line, left click the Properties button, then select the Settings tab. At the bottom of the Settings properties page, check the "Allow LPT Interrupt Sharing" checkbox, select "Apply", then "OK". Restart the PC
And then,....
reboot, test,
And then,....
reboot, test,
And then,....
reboot, test,
And then,....
reboot, test,
And then,....
reboot, test,
But that did for now. Good Luck if you have the same problem.
