Hi, I’m new here,
and I would like to know if the drive configuration I plan to do on my first self-build computer makes sense. I would really love it if it worked!
Some of my Xwares:
One 64GB Crucial M4
One 2TB WD Caviar Black
Asus P8Z68 Deluxe motheboard
Windows 7 Ultimate
Setup
A SSD partitioned in 2: one partition for the OS alone (I plan 30GB), and another one for the SSD caching of a partitioned HDD (what remains, so approx. 34GB).
A HDD in 2 extended partitions. The first (500GB) for all my programs and games. I would also put the pagefile there to free some space out of my SSD (not hiberfil because I don’t need it and I will disable it anyway). This would obviously be the HDD I would use the Intel SRT on. And the second partition (1500GB), for all my data (documents, music, movies, etc).
And eventually, an external drive as backup for the HDD.
In my opinion, I suppose:
Having the OS alone on one drive with no other programs, makes the reinstallation easier if it fails. Now, I can even think about formatting my SSD and reinstalling the OS just for cleaning purposes without the pain of having to reinstall all of my programs.
I get the SSD speed for my OS, and almost as fast speed for the programs I frequently use.
So my questions are:
Is it possible?
I have already seen a comment about someone having done a SSD caching on a HDD without OS (the opposite supposedly necessary according to Intel. See this thread and the comment by ratbuddy. http://www.overclockers.com/forums/showthread.php?t=677928
Also, I read that SRT is possible only for 1 SSD and 1 HDD or 1 SSD and 1 RAID Array (see the Intel Smart Response Technology User Guide, link too long to put here! ). Would the partition of my HDD prevent me from using the SSD caching feature?
Is it a suitable solution?
From my amateur DIY opinion, I don’t see much disadvantages about this, apart from:
1) Being a little bit more complex to set up than a conventional SSD for OS and programs, and HDD for data.
2) The possible increase wear rate of my SSD for using the SRT (severals writes and deletes) on a non-SLC SSD.
Great thanks for your enlightening opinions, but mostly, please tell me it will work!!!
Seiphyr
PS. My parts are coming soon!
Some of my Xwares:
One 64GB Crucial M4
Windows 7 Ultimate
Setup
Is it possible?
Seiphyr
