- Mar 26, 2003
- North America
That cooler looks exactly like the ones on my PowerColor 3870 cards.
I got about 7500 ..
I have the same mobo as you (an AsRock 4core dual sata2). Our pcie slots are 4x. Im running a GeCube x1950pro 512MB card right now and getting a 3DMark06 score at 5500...everything at stock and default. I still reach 5000 with 4xaa/8xaf with temporal and adaptive aa turned on and af set to hq and full trilinear. I have a quad core Q6600 cpu. Is 7500 around what I should expect for 3DMark06 if I get a 3870? Im trying to decide between that and a Geforce 8800GTS 640. Im leaning towards the radeon for image quality (my x1950pro has more vivid colors and higher dynamic range than my old 7950GT and 6600GT but I dont know if thats been sorted out in the newer 8800 cards?) Any recommendations would be appreciated.
about 1.31-1.33vThanks eva2000, been following your progress over at XS...... any idea what the voltages are on those cards after the voltmods?
No, you would get over 7500 with even a 3850. For a quad I would expect closer to 9k for a single card since a quad improved 3d06 scores significantly. As far as comparing the two cards the geforce will have faster peformance with AA and AINSO at the expense of image quality (no its still not as good as ATi, yes I had an 8800gt, its noticably better on ATi).
Given your last card getting a 3870 or a pair of 3850s would be an excellent upgrade.
Probably not a whole lot. The timings should be tighter on the 3850 cards.
I wouldn't say all that. A 3850 with core voltage bumped up to default 3870 volts still doesn't seem to be getting them as high as an overclocked 3870 on default voltage. The difference may be small depending on the application yet if you're a bencher like me then you'll want the 3870. I haven't seen any tests that determine if the DDR3 on the 3850 can be volted enough to approach the same performance of the 3870 DDR4. My guess is it would be similar but still not as good.
Hey guys,
When I try to flash my 3870 BIOS with winflash I get "subsystemIDs mismatch." Am I using the wrong bios or whats the deal? I have a sapphire 3870 and vista 64-bit. Any Ideas?
