Cards are flashed with the bios fix. Everything you need is in post #1. Good luck and good hunting.
16K+ with a E6850 at 4Ghz...... still testing for max. That was at 860/1301.What did you bench in 06 in crossfire?
How do they clock in crossfire too?
After a very quick test with the TT Duorb vs Stock Cooler my findings are that the Stock cooler is good enough.
E6850 @ 4Ghz, HD 3870 @ 860/1301 - Room temps at 18°C - setup is not in a case
Stock Cooling @ 60% highest load is 54°
TT DuOrb highest load is 53°
Both are pretty silent....... take that how you want to.....
so your crossfire results are with 16/4 crossfire ?
I have two and did some benching. Haven't got Crysis yet but I'll soon post what I have.
Also, Catalyst 7.11 was just released........
http://ati.amd.com/support/driver.html
is that 81C just sitting there? That's hot I hope u were just gaming lol. As far as 860, incase you havn't read the card needs a bios flash to clock above 860. I don't think i'll touch my clocks until I get a cooler. The core and clock speeds on these cards are absolutely insane.
I know people bash ATI lately because they havn't beaten nvidia, but what in the world do they have to do in order to do it??
These cards have much higher theoretical bandwidth and FLOPS at stock speeds and even hit these insane clocks. It surprises me that they aren't performing much better.
Did you adjust the fan speed at all? If not your fan is running at 29% which is not enough to keep these cards cool.that temp was from continously testing the speeds. these things to run a bit hot just stock x.O
