That BD drive is still occupying the sata port which may be interfering with the m2 drive. It only takes a second to move the cord and worse that will happen is it does not help.
Its funny that i built this Rig but cant find where i can add my signature in this forum. i have being struggling to find it lol
anyway I appreciate it if you tell me how
Did you try moving that Sata cable? Have you tried it in the other slot?
What (slot) does your manual say to install it to????
So............wait... what is the problem?
Didn't you mention a few posts ago that you installed windows? Why are we still messing around with the BIOS and cables and calling Giga and Sandisk......etc?
I'm not even sure which M.2 SSD model you're using and how many different versions there are (PCIe or SATA) but a quick search showed that the M.2 SSD 1 TB from Sandisk is a SATA and not a PCIe version. Check your MB's manual and see which M.2 interface it should be in and if it's compatible.
If it's a sata m.2 you will have to put it in m.2 mode. Pci-e m.2 you leave at default because it uses the achi sata controller to use the chipset to convert it to pci lanes. (At least I am pretty sure this is how mine works)
Some of these (well maybe all of them) M.2 themselves have firmware. The actual M.2 may even need a firmware update.
That would be about the most terrible thing I can think of if it's a defective board that has been painted Neon Green before testing.
I had one friend with the Rampage v Ed 10 who had the same issue with a 950 Pro. He had to install windows on his 1tb (Sata) ssd then dl and install M.2 drivers then Migrate to the M.2. Then two days later he ended up dpoing a fresh install anyway and it was in the available drives to choose from in the install setup. So if worse comes to worse if you have any (Sata) drive at all you can hook up real quick to the board, throw windows on there and try what I suggested above. Idk why, he doesn't know why, but he did that and hasn't had a problem since.
LOL he couldn't recognize it in bios either until he did that idk why but once he installed the driver he was able to get windows to recognize it in in Disc Management, then when choosing custom install later he was able to choose it to install on. Find a cheap 320 GB spinner on offer up for 10-20 bucks and give her a shot or go thru a few weeks of Rma and hope that works.
Once it's recognized in Windows it'll then be recognized by Windows Install Wizard from the Custom Install screen.
Ya I suggested that earlier in a way with a link, integrating the driver into the bootable usb with the Gigabyte bootable usb utility. It's up there somewhere. I would try a newer bios if thers anything past f8 do it give it a shot I wish I was able to help more I will try and track down more real fast. I'll take a break from bf1 for ya.
not gonna lie, never being a fan of call of duty or battlefield and never played them. but bf1 got it. i have to. im more old school. counter strike 1.6 lol but bf1 definitely in 4k. not gonna be 60fps of course but thats ok
