G.Skill has just updated its Trident Z Neo DDR4 memory for the upcoming Ryzen 5000 series CPUs. Optimized for extreme frequency, low latency, and high capacity, there are three sets to choose from. The high-speed kits are rated for speeds up to DDR4-4000Mhz with timings set to CL16-19-19-39 32GB (16GBx2). For ultra-low latency, there is the DDR4-3800 CL14-16-16-36 32GB (16GBx2) set. If high capacity is your thing, the new Trident Z Neo also offers a DDR4-4000 CL18-22-22-42 64GB (32GBx2) kit. As with all G.Skill memory, these will come with a limited lifetime warranty. Continue reading for more about the updated G.Skill Trident Z Neo.
G.SKILL Updates Trident Z Neo DDR4 Specs Up To DDR4-4000 CL16 16GBx2 for AMD Ryzen 5000 CPUs
(5 November 2020) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is announcing new DDR4 memory specifications under the Trident Z Neo series, optimized for the new AMD Ryzen 5000 processors. Featuring ultra-high speeds of up to DDR4-4000 CL16-19-19-39 32GB (16GBx2), extreme low latency at DDR4-3800 CL14-16-16-36 32GB (16GBx2), and high-capacity kit at DDR4-4000 CL18-22-22-42 64GB (32GBx2), these memory kits are the perfect choice for PC enthusiasts and gamers looking to push memory bandwidth to the extreme limits on the new AMD Ryzen 5000 processors.
Optimized for Extreme Frequency, High Capacities, & Low Latency
With the improvements of memory support on the latest AMD Ryzen 5000 processor series, the R&D team at G.SKILL is always looking to push the performance boundaries even further and have expanded the G.SKILL Trident Z Neo series with higher performance options, whether you’re looking for extreme frequencies, high kit capacities, or extreme low latency.
At high memory frequency speed, the Trident Z Neo DDR4-4000 CL16-19-19-39 32GB (16GBx2) raises the memory speed support for AMD platforms to DDR4-4000 from the previous generation of processors. Built with high performance Samsung B-die components, this memory kit also features a low latency of CL16. Seen below, this memory specification can be seen running in 1:1 ratio on the ASUS ROG Crosshair VIII Dark Hero and MSI MEG X570 GODLIKE motherboard with the latest AMD Ryzen 7 5800X and Ryzen 5 5600X processors.
For high kit capacity, the Trident Z Neo DDR4-4000 CL18-22-22-42 memory kit is available at an astounding 64GB (32GBx2). As seen in the screenshot below, this memory kit behemoth is running at 1:1 ratio on the ASUS ROG Crosshair VIII Dark Hero and the MSI MEG X570 GODLIKE motherboard with the AMD Ryzen 7 5800X and Ryzen 5 5600X processors.
Pushing the limits on extreme low latency, the Trident Z Neo DDR4-3800 CL14-16-16-36 32GB (16GBx2) kit is the ultimate choice for high efficiency. Engineered with high performance Samsung B-die components, this kit can be seen in the screenshots below running at a ratio of 1:1 on the ASUS ROG Crosshair VIII Dark Hero motherboard with the AMD Ryzen 7 5800X processor.
Availability & Specifications
These ultra-speed, high-capacity, and extreme low latency memory kits will be available via G.SKILL worldwide distribution partners at the end of November 2020. For a full list of released specifications, please see the table below.
About G.SKILL
Established in 1989 by PC hardware enthusiasts, G.SKILL specializes in high performance memory, SSD products, and gaming peripherals designed for PC gamers and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house testing lab and talented R&D team, G.SKILL continues to create record-breaking memory for each generation of hardware and hold the no. 1 brand title in overclocking memory.
Loading new replies...
Benching Team Leader
