Alphacool launched three new Nvidia 3000 series water blocks for its Eisblock Aurora Acryl GPX-N series. All three are said to provide exceptional cooling due to their nickel-plated copper cold plate and functional aluminum backplate. The new blocks are engineered to be compatible with the INNO3D RTX 3070, Gigabyte’s RTX 3080 Eagle, 3090 Eagle, 3080 Gaming, and finally an RTX 3090 Founders Edition. Pricing starts at €126.99 or about $150 USD. Here is the press release from Alphacool.
Alphacool presents three new Eisblock Aurora Acryl GPX-N blocks for the Nvidia RTX 3070, 3080 and 3090 graphics cards. The blocks offer outstanding cooling performance thanks to the full cover design. The new backplate, which is included with the coolers, also contributes to this. This stabilizes the graphics card and ensures an even contact pressure of the cooler. The cold plates are made of solid nickel-plated copper. The coolers cover all relevant components such as voltage converters and the graphics memory.
Data Cooler
L x W x H
122 x 239 x 25 mm
Material cooler
Nickel-plated copper
Material cooler top
POM clear
Threads
4 x G1/4″
Thickness cooling fins
0,6 mm
Data Backplate
L x W x H
97 x 239 x 6 mm
Material
Aluminum
Color
Black
Compatible to:
– INNO3D GeForce RTX 3070 iCHILL X3, 8GB GDDR6, HDMI, 3x DP (C30703-08D6X-1710VA38)
– INNO3D GeForce RTX 3070 iCHILL X4, 8GB GDDR6, HDMI, 3x DP (C30704-08D6X-1710VA35)More compatible models will follow in this list for this cooler. We are currently checking other PCB designs from various manufacturers!
MSRP: 126.99 €
Downloadable data sheet: ENG_1020382_Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_3070_Reference_with_Backplate.pdf.pdf
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Gaming/Eagle with Backplate
Data Cooler
L x W x H
122 x 233,5 x 24,5 mm
Material cooler
Nickle-plated copper
Material cooler top
POM clear
Threads
4 x G1/4″
0,6 mm
Data Backplate
L x W x H
97 x 233,5 x 6 mm
Material
Aluminium
Color
Black
Compatible to:
– Gigabyte GeForce RTX 3080 Eagle OC 10G, 10GB GDDR6X, 2x HDMI, 3x DP (GV-N3080EAGLE OC-10GD)
– Gigabyte GeForce RTX 3080 Gaming OC 10G, 10GB GDDR6X, 2x HDMI, 3x DP (GV-N3080GAMING OC-10GD)
– Gigabyte GeForce RTX 3090 Eagle OC 24G, 24GB GDDR6X, 2x HDMI, 3x DP (GV-N3090EAGLE OC-24GD)MSRP: 136.98 €
Downloadable data sheet: ENG_1020558_Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_3090-3080_Gaming_Eagle_with_Backplate.pdf
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 Founders Edition with Backplate
Data Cooler
L x W x H
120,7 x 231,5 x 29,2 mm
Material cooler
Material cooler top
POM clear
Threads
4 x G1/4″
0,6 mm
Data Backplate
L x W x H
120,7 x 206,5 x 6 mm
Material
Aluminium
Color
Black
Compatible to:
– NVIDIA RTX 3090 Founders Edition
MSRP: 129.99 €Downloadable data sheet: ENG_1020498_Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_3090_FE_with_Backplate.pdf
Related Articles
No replies yet
Loading new replies...
