Alphacool just announced another Nvidia 30 series water block. The Eisblock ES Acetal GPX-N RTX 3090/3080 GPU water block is the full-cover type with nickel-plated copper and an acetal top. One of the unique features of this block is its two G1/4″ inlet ports located on the end of the block as opposed to the top. This is said to work for server applications as well as in a normal desktop configuration. These are priced around $165 USD. Here is Alphacool’s announcement.
Alphacool Eisblock ES Acetal RTX 3080/3090 Reference
Alphacool presents the Eisblock ES Acetal GPX-N RTX 3080/3090 GPU watercooling block. The block is specially developed for the server sector. Nevertheless, it also fits into normal desktop computers or small form factor cases. Of course, it is also available to our end customers.
A special feature of this block is the terminal with the G1/4″ ports is located at the rear end of the cooler. This arrangement saves space and makes it much easier to lay and connect the tubing, especially in server cases.
Alphacool naturally only uses copper in its water coolers. In the Eisblock ES Acetal GPX-N RTX 3080/3090 the copper is nickel-plated. Compared to the previous models, Alphacool has improved the type of nickel plating again, which significantly increased the acid resistance.
Alphacool Eisblock ES Acetal GPX-N Specifications L x W x H 97 x 253 x 27 mm Net weight 1000 g Material cooler Nickle-plated copper Material cooler top Acetal Threads 2 x G1/4“ Thickness cooling fins 0,6 mm
Compatible with:
RTX 3080
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
Zotac Gaming GeForce RTX 3080 Trinity OC (ZT-A30800J-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3080 GG-RTX3080-E10GB/TPRTX 3090
PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24576 MB GDDR6X (VCG309024TFXPPB)
Inno3D GeForce RTX 3090 iChill X3, 24576 MB GDDR6X (C30903-246XX-1880VA37)
Inno3D GeForce RTX 3090 Gaming X3, 24576 MB GDDR6X (N30903-246X-1880VA37N)
Inno3D GeForce RTX 3090 iChill X4, 24576 MB GDDR6X (C30904-246XX-1880VA36)
Zotac GeForce RTX 3090 Trinity, 24576 MB GDDR6X (ZT-A30900D-10P)
Palit GeForce RTX™ 3080 GamingPro (NED3090019SB-132BA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3090S19SB-132BA)
Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
KFA2 GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
Gainward RTX 3090 Phoenix
Gainward RTX 3090 Phoenix GS
Galakuro NVIDIA GEFORCE RTX 3090 GG-RTX3090-E24GB/TPMSRP: 139,99 € ($165.35USD)
Related Articles
Loading new replies...
