Table of Contents
With new video cards set to release by the end of the calendar year (2024), we’ve updated our testing suite to new games and benchmarks to bring you performance metrics from various titles using the latest technologies from AMD, Intel, and Nvidia.
This article will serve as a reference for those who would like to compare results with our reviews, whether you are writing an article for the site or just testing the performance of your new GPU. The plan is to update the article as changes in our testing procedures occur. On to the gritty details…
Test Platform
(Updated: 3/2024)
Our test systems consist of mainstream parts since most people will use them. This allows our results to be relevant to a wider audience and allows that audience to repeat our tests to compare with their systems. The required parts and clocks are as follows:
Test System Components | |
Motherboard | Gigabyte Z690 Tachyon (F28 BIOS – 12/23) |
CPU | Intel i9-14900K @ stock |
CPU Cooler | CoolerMaster Master Liquid PL360 Flux |
Memory | Kingston 2x16GB DDR5-6000 (36-38-38-80) |
SSD | 2x 1TB PCIe 4.0 x4 NVMe (OS + Applications) |
Power Supply | EVGA 850W P6 |
Driver Version | Nvidia – 551.61 (2/2024), AMD – 24.2.1 (2/2024) |
Synthetic Benchmarks
(Updated: 3/2024)
Synthetic benchmarks are very consistent and easily repeatable, making them some of the best tests for direct card-to-card comparisons. We have dropped support for Unigine Heaven and Valley and will continue with 3Dmark Fire Strike Extreme and Time Spy, along with Port Royal, where applicable.
3DMark – Fire Strike Extreme (DX11 benchmark)
3DMark – Time Spy (DX12 benchmark)
3DMark – Speedway (DX12 Ultimate benchmark)
3DMark – Port Royal (Real-time ray tracing benchmark)
- Run at default settings (you do not need to run the demo)
Unigine Superposition
For 2024, we’ve increased the difficulty in this benchmark, moving up a more stressful “4K Optimized “setting from the 1080p High we used since it was introduced in 2020.
Game Benchmarks
(Updated: 3/2024)
We have updated our gaming suite to remove some of the older titles. Now, all of the benchmarks are “canned” tests, making them as consistent as possible and more synthetic-like than typical gameplay. While this may not be the most accurate reflection of in-game performance, most are in the ballpark. The idea here is to show the relative performance and relative performance difference between the tested cards.
We test with the still most common (according to Steam statistics) resolution of 1920 x 1080, 2560 x 1440, and 3840 x 2160 using the canned/default Ultra settings and any manufacturer-specific features disabled/minimized where possible. Ray tracing and DLSS/FSR are tested at 2560 x 1440 and 3840 x 2160 with DLSS/FSR set to balanced and ray tracing to high or ultra.
Below, we’ve provided several screenshots of the video and graphics settings.
Assassin’s Creed: Mirage
AC:M should be set up as follows using the integrated benchmark:
- Ultra High Preset
- Resolution scale to 100%
- Adaptive Quality = OFF
- Upsample Type = TAA
…with DLSS/FSR
- DLSS, or FSR
- Upsample Quality to Balanced
F1 2023
We use the integrated benchmark using the Las Vegas track with Clear/Dry (default) settings:
…without RT:
- Ultra High Detail preset
- RT Shadows/Reflections/AOccl/Trans Reflections/DDGI = Off (for non-RT runs)
- Anti Alaising – TAA Only (for non RT runs)
…with ray tracing:
- Ray tracing – RT Shadows/Reflections/AOccl/Trans Reflections/DDGI = On
…RT + DLSS /FSR:
- Anti Aliasing – Nvidia DLSS/AMD FSR2 , Anti Aliasing Mode = Balanced
Avatar
Integrated benchmark
…without RT:
- Ultra settings to start
- Scaling Mode = Off
- Sun Contact Shadows = Off
- Specular Reflections = Very Low (no off)
- Diffuse Reflections = Low (no off)
…with ray tracing:
- Sun Contact Shadows = High
- Specular Reflections = Very High
- Diffuse Reflections = High
…RT + DLSS /FSR:
Temporal Upscaler = Nvidia DLSS or AMD FSR 3
- Scaling Mode = On
- Scaling quality = Balanced
Cyberpunk 2077
…without ray tracing/DLSS:
- Quick Preset = Ultra (turns to custom)
- Resolution Scaling = Off
- Ray Tracing Reflections/Sunshadows/Local Shadows = Off
- Path Tracing/Tracing in photo mode = Off
…with ray tracing:
- Quick Preset = RT Ultra (turns to custom with DLSS/FSR)
- RT Lighting = Ultra
- Ray Tracing Reflections/Sunshadows/Local Shadows = On
…RT + DLSS/FSR:
- Resolution Scaling = DLSS or FSR
- DLSS/FSR Quality = Balanced
Far Cry 6
Integrated benchmark settings are as follows:
…without ray tracing:
- Graphics Quality = Ultra
- HD Textures = On
- Anti Alaising = TAA
- DXR Reflections/Shadows = Off
…with ray tracing:
- DXR Reflections/Shadows = On
Shadow of the Tomb Raider
Run the integrated benchmark using the following settings:
- DX 12
- Graphics Preset = Highest (turns to custom)
- Ray Traced Shadow Quality = Off
…with ray tracing:
- Ray Traced Shadow Quality = Ultra
- Nvidia RTX DLSS = Off
… RT + DLSS:
- Nvidia RTX DLSS = Balanced
Additional Testing
(Updated: 3/2024)
The following are a few things that will provide additional value and detail to the testing.
Temperature
We are measuring typical temperatures to expect and testing cooler performance.
- Record ambient temperature in degrees Celsius (preferably close to the intake fan of the GPU)
- GPU-Z will be used for monitoring temperatures during the test
- Record the GPU’s idle core (not hot spot) temperature in degrees Celsius after the card has been on and in the idle state for a few minutes
- Run F1 2023 (5 laps) benchmark using 4K UHD 3840×2160 resolution (w/RT + DLSS/FSR) and record the peak temperature in degrees Celsius with the default fan profile (other manual fan speeds can be tested as well).
- Run Cyberpunk 2077 benchmark using 4K UHD 3840×2160 resolution (w/RT + DLSS/FSR) and record the peak temperature in degrees Celsius with the default fan profile (other manual fan speeds can be tested as well).
- When comparing temperature results, they must be normalized to the same ambient temperature (23C).
System Power Consumption
Have GPUz running while testing. Use the Total Board Power value (max) to find the peak power for the graphics card only.
- Record the system power consumption at idle
- Record peak power consumption during the following two benchmarks: F1 2023 and Cyberpunk 2077 benchmarks (same settings as recording temperature) at 3840×2160 resolution (w/RT and DLSS/FSR).
Folding @ Home
For all of the folders out there, we test this running for a full 24 hours to get the PPD across that time. We run at stock settings and record average power (the GPU) and list clockspeeds.
Conclusion
Nope, this definitely isn’t the “conclusion” of this article; it will be slowly evolving, just like our GPU testing procedures. We’ll post comments with changes as they happen, so please keep an eye on this, the comments, and the forum thread for updates. We are always open to feedback and suggestions as well. So, if you think something worth testing is not included, feel free to speak up in the comments below.
– Joe Shields (Earthdog)
Please leave any comments or suggestions in the thread!
Loading new replies...
What have I done! Member
Gulper Nozzle Co-Owner
