SUMMARY: Entry level kit with modest performance.
The good guys at Jetart were nice enough to send samples of the Aquacool Liquid Cooling System watercooling kit.
Key Features:
- Copper radiator (3″ x 4″ face) and aluminum case
- Blue light LCD monitor
- 92 mm double ball bearing fan, adjustable to 1550–3100 rpm, 25 ~ 35 dBA
- AC Waterpump, 230 lph, head 0.8 meters
- Adjustable CPU temp & fan speed alarms
- Remote temperature sensor
- Aluminum Alloy Case
- Easy fill port and water level indicator
- Mounting clips for P4 and Socket A
The front shows the LCD, adjustment knob and fill port:
Filling the system is better than most kits I’ve seen – the funnel-like front allows users to easily fill the system without using an eyedropper. A minor annoyance: The thread on the cap requires precisely locating it to screw on – maybe it’s me, but it took a few tries to get it right.
The unit has alarm adjustments for temperature and fan state – if the temp is exceeded or the fan stops, the alarm will sound. The knob also controls fan speed – it should be turned slowly to dial in fan speeds.
The back
shows the waterpump, tubing and wiring. The bottom
shows the radiator – the fan pulls air from the top and exhausts through the bottom (IMHO the reverse of what I would have done). The top
shows the 92mm fan intake – very clean looking top. The waterblock
features a dimpled copper base with a plastic top. A look inside
clearly shows the dimpled base and the flow directors built into the plastic top. Tubing is secured to the top with screw connectors. The base
is polished and smooth – no discernable polishing marks to the eye or touch.
{mospagebreak}
Opening the unit revealed a bare fan connector:
Not a good practice; if it hits some metal, it will possibly short out. This is easy enough to fix – there is a small aluminum plate on the bottom held on by two screws – easy enough to open and tape the connector.
The unit is fairly simple – the PCB/LCD is in to the left, the radiator (3″ x 4″) in the middle with the 120 volt pump at the end:
The radiator is joined to the pump with a plastic connector:
There is a plenum on the radiator which acts as a reservoir.
The Jetart Aquacool was tested using the CPU Die Simulator. I tested with the rheostat set at its lowest and highest setting. I found system noise at the fan’s lowest setting fairly quiet at 53 dBA and busier at the highest setting – about 59 dBA (measured 8″ from the fan’s intake).
In addition, I heard continual burbling noises due to bubbles in the line that I could not get rid of, even with the unit as full as I could get it. I even ran the unit for four days straight to see if it would work itself clear – no dice. Finally, I happened to tip the unit up about an inch and the gurgling and bubbles stopped! I surmise that the pump’s intake is close enough to the water’s surface to create a suction vortex, pulling in air even though I filled it to the brim. If you get the same noise, try tipping the front of the base unit up a bit.
The impact on performance is substantial – don’t run this unit (or any watercooling system) with lots of bubbles in the line.
State | Die Temp | Ambient Temp | Delta | C/W |
Aquacool Fan High, 2410 rpm, 59 dBA¹ | 50.1 | 24.0 | 26.1 | 0.37 |
Aquacool Fan Low, 1470 rpm, 53 dBA¹ | 52.5 | 24.3 | 28.2 | 0.40 |
¹Measured 8″ from the fan’s intake; manufacturer dBAs usually measured at 1 meter.
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU
consumes, the HSF will limit the CPU’s temperature rise to (C/W x CPUw)
plus the temperature at the HSF’s fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the Jetart Aquacool in the mid rank of watercooling kits tested to date (Heatsink Ranking).
The Jetart Aquacool tested about where I thought they would – OK for an entry level kit and OK for non-aggressive cooling. With the exception of the curable gurgling noise, the unit was fairly quiet at low rpms and not too noisy at full fan speed, but noticeable.
Users should note that the pump’s head is a minimal 0.8 meters – minimize the vertical distance between the base unit and CPU as much as possible for best performance.
Thanks again to Jetart for sending this our way to check out.
Be the first to comment
