MSI Announces MEG B550 Unify and MEG B550 Unify-X Motherboards
MSI has just announced two new motherboards in preparation for the upcoming AMD Ryzen 5000-series CPU’s. The MEG B550 Unify and Meg B550 Unify-X are geared towards serious overclockers boasting new world records once again. Equipped with the B550 chipset, both models are compatible with Ryzen 3000 and 5000 series processors(except Ryzen 5 3400G and Ryzen 3 3200G).
The MEG B550 Unify is loaded with features. There are four M.2 connectors, three of which have the lightning-fast Gen 4 capabilities. The included heatsinks are double-sided for maximum cooling. Overclocking is made possible due to its direct 14+2 power phases and beefy 90 Amp power stages.
The MEG B550 Unify-X is for the extreme overclocker and only features a pair of DDR4 slots. This is said to yield a clearer memory signal and allow for increased memory overclocking.
The retail price has not been released as of the time of this article, but expectations are for them to be in around the $250-$300 range, right around where the current MEG X570 Unify boards sit. Here is MSI’s official press release.
MEG B550 UNIFY SERIES – PURE BLACK, PURE PERFORMANCE
[Taipei, Taiwan] – MSI, a world-leading gaming motherboard manufacturer, proudly announces the new flagship AMD B550 motherboards – MEG B550 UNIFY and MEG B550 UNIFY-X. The spirit of the UNIFY series consists of modest and pure black design, emphasizing the real value of the motherboard that can be brought to the demanding gamers and power users instead of fancy LED decorations. By eliminating all the redundant RGB LEDs and adopting the UV black printing, the heatsink shows the gleam and the shining reflection of the dragon that symbolizes a mysterious and high-quality image. For the UNIFY series motherboard, MSI put great efforts into those essential parts concerned by those enthusiast gamers, enhancing not only the thermal but also power solution to run with the AMD Ryzen processors.
Emphasizing the ultimate performance, MEG B550 UNIFY brings astonishing overclocking records to enthusiast gamers. With AMD Ryzen 5 3600XT processor, it is an incredible result to push CPU frequency to 6155.35 MHz, becoming the world’s record breaker once again.
Please check https://valid.x86.fr/8ki3vn for more information
QUADRUPLE M.2 CONNECTORS WITH DOUBLE SIDE SHIELD FROZR
MEG B550 UNIFY series motherboard features exclusive onboard quadruple M.2 connectors for the maximum storage performance. Three of them support Lightning Gen 4 solution which is the fastest onboard storage on the market with up to 64 Gb/s transfer speed.
To sustain the higher performance of ultra-fast storage devices, the MEG B550 UNIFY series motherboard features exclusive double-sided M.2 Shield Frozr. This next-generation M.2 thermal solution prevents throttling by offering the best thermal protection to make sure that SSD maintains maximum performance.
DIRECT 14+2 PHASES WITH 90A POWER STAGE
To handle the high-performance CPU, the MEG B550 UNIFY series motherboard features extreme power designs including a total of direct 14+2 digital power phases, 90Amp power stage and Titanium choke III. Combining dual power connectors and exclusive Core Boot technology, the MEG B550 UNIFY series motherboard is ready to break the world record.
PREMIUM THERMAL SOLUTION
Cooling is what an enthusiast gamer would care about and the MEG B550 UNIFY series motherboard adopts a premium thermal solution to cool down your system. An aluminum cover with an extended heatsink on top of the power delivery circuits can effectively help dissipate excessive heat. Other than that, a heat-pipe connected from this larger heatsink to another MOS heatsink and an improved thermal pad means better heat conduction.
2.5G LAN WITH WI-FI 6 AX
MEG B550 UNIFY series motherboard features onboard 2.5G LAN plus the latest Wi-Fi 6 AX solution. 2.5G LAN provides incredible data transfer speed faster than ever before. The Wi-Fi 6 AX solution is a revolutionary network with up to 4x network capacity and efficiency in high signal density environments.
DEDICATED FOR EXTREME OVERCLOCKING
The MEG B550 UNIFY offers 4 DIMM slots, but there is a special edition for extreme overclockers – MEG B550 UNIFY-X. This model comes with only 2 DIMM slots for an even clearer memory signal to explore the boundaries of memory overclocking and is ready to surpass all limits!
MSI’s in-house overclocker, Kovan Yang pushing the DDR4 speeds to an incredible 6536MHz, show the strength on memory overclocking performance for MEG B550 UNIFY-X.
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Gabber359
201 messages 0 likes
Nice read, thanks. I've been looking for a board to buy and these might be it. B550 but the specs seem to read like a X570. Also, paper launch so far it seems, as I cannot find them in stock anywhere. Got a bit confused because it seems there's a X570 Unify series as well. I'll be curious to see what price point they drop in at. If it's dead close to the X570s then there'll have to be a hard comparison on which is more worth it.
Reply Like
W
Woomack
1
12,921 messages 1,848 likes
I've purchased the X570 Unify after reading about B550 Unify/X. Prices for some reason will be not much different and when I buy full ATX motherboard then I expect to use some more PCIe slots and other things. For memory and CPU OC I can use cheaper motherboards with the same or not much worse effect.
Reply Like
Blaylock
1
7,973 messages 783 likes
Gabber, this article was a product announcement and not an actual launch. That's why you haven't found these yet. I don't know when they will actually launch unfortunately, though I do expect it to be very soon. It's more than a little curious to me why they would manufacture such a high-end 'extreme' overclocking board on a lower than top tier chipset. With pricing expected to be only slightly lower, I would make the assumption that it would be marketed towards competitive benchmarking for those who don't have a need for Gen 4 lanes.
Reply Like
W
Woomack
1
For some reason B550 motherboards are overclocking memory better than X570. This is probably why MSI makes X series on B550 chipset. CPU performance is the same. Maybe it's less complicated and easier to provide clean signal, I'm not sure. X570 is heating up more and costs more so getting B550 is a win for both sides... as long as it will sell with high enough margin for the manufacturer and low enough price for end-users.
All manufacturers are adding something for the Ryzen 5000 premiere. ASUS released two new motherboards, ASRock one and probably Gigabyte will show something soon too... but they recently refreshed most of their line marked as V2. I only don't get these mobos with one PCIe x16 and 4 M.2 sockets. The same has ASUS. I mean who needs 4 M.2 sockets on a motherboard like this. They could make high-end micro ATX with B550 chipset as there are not many good mATX mobos for AMD.
Reply Like
