Chipset waterblock test – Joe
SUMMARY: Very good choice for chipset cooling with moderate power waterpumps.
Silverprop was nice enough to send a Cyclone NexusLX waterblock to test.
The NexusLX features
- ½” integrated hose fittings with only one seal between the top & base
- Channelled base
- Type II, Class 2 Anodization for corrosion resistance
You will notice below that the NexusLX’s pressure drop is low+; this is due to its interior design:
No such thing as a free lunch – increasing turbulence and channelling waterflow will require some “effort”, and it shows up in pressure drop readings (not good or bad – just something to recognize).
The Cyclone Nexus LX is compatible with most chipsets (center hole distance 59mm/2.32″) and on Intel ® 865/875 motherboards (center loop distance 77.75mm/3.06″) via an optional 865/875 clip.
The base
appears well finished, although performance could be enhanced a bit by very well done hand lapping.
The Silverprop NexusLX was tested using the CPU Die Simulator and Waterblock Test Rig. Even though this is a chipset waterblock, testing it as a CPU waterblock should be rigorous enough for any application.
Waterblock | C/W | Pressure Drop – psi | Pressure Drop – inches H2O |
Silverprop NexusLX | 0.16 | 0.49 | 13.6 |
Unrounded data: 0.161 C/W with 0.0017 std dev.
Test Results indicate that the NexusLX’s pressure drop (or head loss) across the waterblock is low+; flow resistance such as this means that Silverprop’s NexusLX NexusLXs should function OK without using a very large waterpump, although anything less than 300 gph might compromise results, depending upon how restrictive other components are in system.
As with many waterblocks, I found that reducing flow to 0.5 gpm resulted in more of a performance decrease (about 1ºC) than the gain by increasing flow to 1.5 gpm (about 0.7ºC).
For a comparison of the NexusLX’s performance to other waterblocks tested to date, see Overclockers.com Waterblock Test Results.
Silverprop’s NexusLX Chipset Waterblock is a good choice for chipset cooling. Flow resistance is not unduly high, and the NexusLX will perform very well with moderate power waterpumps (300 gph). Users including a chipset waterblock should recognize that placing waterblocks in series will increase pressure drop.
Thanks again to Silverprop for sending this our way.
Be the first to comment
