EVGA GTX 750 Ti FTW Graphics Card Review
NVIDIA has another architecture release day for us! The Maxwell GPU core has arrived at Overclockers in the form of an EVGA GTX 750 Ti FTW. The Maxwell GPU core architecture promises great power efficiency, low power consumption, and performance that surpasses its predecessors. This particular card also comes with EVGA’s ACX cooler, which has tested very well in the past on other EVGA video cards. So, let’s find out if EVGA put this new technology to good use as we run the GTX 750 Ti FTW through our testing procedure.
Specifications and Features
As we look at the specifications below, right off the bat we can see that EVGA has factory overclocked the card from reference design speeds. The reference design card has a base clock of 1020 MHz and a boost clock of 1085 MHz, but here we have 1189 MHz and 1268 respectively. I’d say that’s a pretty hefty overclock right from the start. The card also features 2 GB of GDDR5 memory set to a quad-pumped speed of 5400 MHz. Another added bonus is the inclusion of a 6-pin PCI-E power connection, whereas there is no such connector found on the reference design cards. Specifications provided by EVGA.
EVGA GTX 750 Ti FTW Specifications
Graphics Processing Clusters1
Streaming Multiprocessors5
CUDA Cores640
Texture Units40
ROP Units16
Base Clock1189 MHz
Boost Clock1268 MHz
Memory Clock (Data rate)5400 MHz
L2 Cache Size2048KB
Total Video Memory2048MB GDDR5
Memory Interface128-bit
Total Memory Bandwidth86.4 GB/s
Texture Filtering Rate (Bilinear)40.8 GigaTexels/sec
Fabrication Process28 nm
Transistor Count1.87 Billion
Connectors1 x Dual-Link DVI
1 x HDMI
1 x DisplayPort 1.2
Form Factor2 Slots
Power Connectors1 x 6-Pin PCI-E
Recommended Power Supply400 Watts/20A +12V
Thermal Design Power (TDP)60 Watts
Thermal Threshold95° C
A quick glance at GPU-Z confirms much of what we see above. History tells us that the actual boost clock usually comes in quite a bit higher than the official specification. This held true with this card too, and it actually boosted up to 1345 MHz when under load.
evga_gtx750ti (39)
For features, we first have a list of those that are more related to NVIDIA and commonly found on most of their newer GPUs.
evga_gtx750ti (1)
We already mentioned the GTX 750 Ti FTW is outfitted with the ACX cooler. I’ve tested EVGA cards in the past that used the ACX cooler and have always came away impressed with how well it works. On the software side, EVGA’s Precision X is quickly becoming the go-to utility for overclocking NVIDIA based GPUs. OC Scanner X is another useful tool for checking overclock stability and monitoring information.
When you buy into the EVGA product line, you get one of the best online community experiences found anywhere. From EVGA’s game servers, social networking, 24/7 tech support to the EVGA forums, you’re always in the loop and can quickly find help when needed.
evga_gtx750ti (2)evga_gtx750ti (3)
evga_gtx750ti (4)evga_gtx750ti (5)
evga_gtx750ti (6)evga_gtx750ti (7)
evga_gtx750ti (8)
I attended a web conference with NVIDIA on February 13th, so they could present information on the new Maxwell platform. I’d be remiss if I didn’t at least parlay some of that information here. It does in fact bring quite a few new features to the GPU world. The first item of note is the GTX 750 Ti and GTX 750 will be the first to use the new Maxwell GM107 GPU core. The GTX 750 Ti is aimed squarely at AMD’s R7 260X, while the GTX 750 stacks up against the R7 260. The GeForce GTX 750 Ti will replace the GeForce GTX 650 Ti in NVIDIA’s GPU lineup, but the GTX 650 and GTX 660 will continue to be produced.
Buying into the NVIDIA GTX family of graphics cards allows the user to take advantage of several GTX Gaming technologies. ShadowPlay, G-Sync, and SHIELD are just a few of the unique NVIDIA technologies that promise enhanced gaming options not found elsewhere. Whether your intent is to stream game play, obtain smooth and stutter free visuals, or even make a video of your game session, you’ll find all the tools you need to accomplish this within the NVIDIA ecosystem.
As NVIDIA put it during the web conference, “The soul of Maxwell is improving performance per watt.” The Maxwell architecture brings a new design to the Streaming Multiprocessor (SM) that improves performance per watt and performance per area. Logic partitioning, workload balancing, clock-gating granularity, number of instructions issued per clock cycle, and compiler-based scheduling are just a few of the many improvements over the Kepler architecture. The number of SMs has increased to five compared to Kepler’s two and done so with only a 25% increase in die area. The L2 cache sees a huge increase from Kepler’s 256 KB to Maxwell’s 2048 KB. With more L2 cache on chip, there is a large drop in requests to the DRAM, which reduces power demand and improves overall performance. To further maximize energy efficiency, NVIDIA states the engineers have aggressively tuned the implementation of each unit in the Maxwell GPU down to the transistor level. In a nutshell, this all boils down to NVIDIA’s claim that Maxwell based GM107 GPUs can deliver two times better performance per watt when compared to a Kepler based GK107 GPU, while continuing to use the same 28nm manufacturing process.
evga_gtx750ti (9)
evga_gtx750ti (10)
One GPC, five Maxwell Streaming Multiprocessors (SMM), and two 64-bit memory controllers (128-bit total) make up the contents of the GM107 GPU. This is the uncut implementation of the GM107 and is what’s found on the GTX 750 Ti. Below is the full chip block diagram showing the GPU configuration.
evga_gtx750ti (11)
Some of you may be interested in the block diagram of the SMM itself, so here that is.
evga_gtx750ti (12)
For a down and dirty comparison, here is a chart summarizing the major improvements the Maxwell GPU provides over the Kepler GPU. Keep in mind, a few of these numbers vary depending on NVIDIA partner card designs, especially when it comes to clock speeds.
GPU GK107 (Kepler) GM107 (Maxwell)
CUDA Cores 384640
Base Clock 1058 MHz1020 MHz
GPU Boost Clock N/A1085 MHz
GFLOPs 812.51305.6
Texture Units 3240
Texel fill-rate 33.9 Gigatexels/sec40.8 Gigatexels/sec
Memory Clock 5000 MHz5400 MHz
Memory Bandwidth 80 GB/sec86.4 GB/sec
ROPs 1616
L2 Cache Size 256KB2048KB
TDP 64W60W
Transistors 1.3 Billion1.87 Billion
Die Size 118 mm²148 mm²
Manufacturing Process 28nm28nm
I wanted to touch on two other aspects I found appealing about the Maxwell based GTX 750 Ti GPU. The first being how it stacks up against the R7 260X in performance and efficiency. Based on the graphs below, NVIDIA claims the GTX 750 Ti outperforms the R7 260X with just a fraction of the power.
evga_gtx750ti (14)
evga_gtx750ti (13)
Secondly, the extremely low power draw makes it an attractive option for HTPC, mITX, or basic store-bought systems that may have smaller wattage PSUs. If you buy a reference design GTX 750 Ti, there won’t be a 6-pin power connector needed, which adds a wider variety of potential usage options. Currently, the GTX 750 Ti is the fastest available graphics card that does not have a power connector. As is the case with today’s review sample, you’ll probably find that NVIDIA partners will add a 6-pin power connector to some of their Maxwell models. The other item that makes the GTX 750 Ti an easy upgrade for a wide variety of systems is the card’s physical size. In its reference form, the card only measures 5.75″ long. Even the EVGA GTX 750 Ti FTW only measures out at a smidgen over 9″ long. Either way, the card will fit into almost any system design out there.
evga_gtx750ti (15)
Upgrade Your Basic PC
As you can see, the new Maxwell GPU brings a lot of new technologies to the table, and it should make for interesting times ahead!
…Now, back to our regularly scheduled program.
Packaging and First Look
The information on the box does a nice job of explaining the product found within. Looking at the box front, you see a few high-level features mentioned, as well as that the card is in the “FTW” family. Around back, the features and specifications we talked about above are displayed. The box sides are a placard for additional branding and a multilingual list of key features.
Inside the box, you will find the GTX 750 Ti FTW well protected in a bubble wrap envelope. Also included are lots of documentation, a DVI to VGA adapter, a PCI-E adapter cable, and the driver/utility CD. EVGA also tosses in a poster, case badge, and a couple different stickers.
First Look/Photo Op
Here are a few pictures of the EVGA GTX 750 Ti FTW taken from different angles. We’ll have a closeup look at the card as the review progresses.
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
EVGA GTX 750 Ti FTW
The EVGA GTX 750 Ti FTW Up Close
The first thing worth noting is the lack of SLI support on the GTX 750 Ti series of cards. It’s understandable that SLI wouldn’t be a feature of this card, as it’s probably not in the class of cards most would consider for that type of setup anyway. The card supports up to three concurrent displays through the available dual-link DVI, HDMI, and DisplayPort connections. As we mentioned earlier, EVGA opted to include a 6-pin PCI-E power connector. Adding this power connector is said to provide a 25 watt boost (30% increase) in power delivery, which should improve overclocking potential.
Display Connectivity
6-Pin PCI-E Power Connector
The ACX cooler features a dual fan design that sits on the aluminum fin stack. There are two large copper heatpipes that pass through the cooling block as they weave their way through the fin stack. This isn’t the most robust implementation of the ACX cooler I’ve seen; but given the smaller size of the card and the low power draw the Maxwell GPU has, it should work just fine. We’ll find out later in the review.
ACX Cooler and Shroud Removed
Heatpipe Design
Heatpipe Design
With the ACX cooler removed, we can get a clear view of the PCB layout. It appears we have a 3+1 power phase design implemented here (3 GPU + 1 Memory).
Bare PCB
Bare PCB
GPU Power Phases
GPU Power Phases
Memory Power Phase
Memory Power Phase
The 2 GB of onboard memory is courtesy of the Samsung K4G41325FC-HC03 GDDR5 memory ICs. Finally, we have a close-up look at the Maxwell GM107 GPU.
Samsung Memory
Samsung Memory
Maxwell GM107 GPU Core
EVGA’s Precision X Software
Precision X has evolved into one of the better GPU overclocking utilities over the past couple of years. It allows for real time monitoring of vital GPU information, overclocking capabilities, and the ability to control the ACX cooler fans. The fan control option allows for setting the speed manually or by using the fan curve option. In the case of this particular video card, there is no power target adjustment available. However, we do have the option to raise the temperature target as high as 95° C. There is a slight core voltage adjustment available as well, but it’s a mere +31 mV. Another item of note is the ability to save up to ten different profiles.
Precision X
Precision X
Precision X
Precision X Voltage Option
To compliment Precision X, you might want to get a copy of OC Scanner X too. It’s a quick way to test GPU overclocking stability and check for any artifacting issues. It even comes with its own monitoring capabilities.
OC Scanner X
OC Scanner X
Overclocking For Stability
It was mentioned by NVIDIA that the GTX 750 Ti would overclock to 1250 base clock without much trouble; and that’s exactly where it landed, while still being able to complete all of the tests in our suite. That might not sound like a lot compared to the 1189 MHz clock the card is factory overclocked to; but when compared to the reference clock of 1020 MHz, it’s actually pretty impressive. The actual boost clock landed at 1407 MHz when the GPU was overclocked to 1250 MHz. On the memory side, I was able to push it to an additional 200 MHz, which landed us at 1550 MHz (6200 MHz quad pumped). Nothing to complain about there either!
1250 MHz GPU/1550 MHz Memory Stable
Ok, now that we have our 24/7 stable overclock established, let’s get to the benchmarks!
Benchmarks
Test System
System Components
MotherboardASUS Maximus VI Formula
CPUIntel i7 4770K Haswell
MemoryG.SKill TridentX DD3-2666 MHz 2x4GB
SSDSamsung EVO 500 GB SSD
Power SupplyCorsair HX1050 Professional Series
Video CardEVGA GTX 750 Ti w/ACX Cooler
CoolingSwiftech Apogee HD CPU Water Block – 360 mm Radiator – MCP35X Pump
We’ll adhere to the Overclockers.com GPU test procedure we have been using since the release of the Haswell platform. If you’re not familiar with our testing method, click on the link provided for more information. For quick reference, below is a synopsis of what we do.
Minimum System Requirements
  • i7 4770K @ 4 GHz
  • Dual Channel DDR3-1866 9-9-9-24
  • GPU @ stock and overclocked
  • Monitor capable of 1920×1080
Synthetic Tests
  • 3DMark Vantage – DirectX 10 benchmark running at 1280X1024 – Performance preset.
  • 3DMark 11 – DirectX 11 benchmark running at 1280X720 – Performance preset.
  • 3DMark Fire Strike – DirectX 11 benchmark running 1920X1080 – Standard test (not extreme).
  • Unigine Heaven (HWBot version) – DX11 Benchmark – Extreme setting.
Game Tests
  • Batman: Arkham Origins – 1920X1080, 8x MSAA, PhysX off, V-Sync off, The rest set to on or DX11 enhanced.
  • Battlefield 4 – 1920X1080, Ultra Preset, V-Sync off.
  • Bioshock Infinite – 1920X1080, Ultra DX11 preset, DOF on.
  • Crysis 3 – 1920X1080, Very high settings, 16x AF, 8x MSAA, V-Sync off.
  • Final Fantasy XIV: A Realm Reborn – 1920X1080, Maximum preset.
  • Grid 2 – 1920X1080, 8x MSAA, Intel specific options off, Everything else set to highest available option.
  • Metro Last Light – 1920X1080, DX11 preset, SSAA on, Tessellation very high, PhysX off.
For the sake of comparison, I’ve chosen four different new generation AMD cards. Because NVIDIA claims better performance than the R7 260 series cards, we’ll use the R7 260X and R7 260 in the comparison graphs. Taking a step up in price and performance, I also used the R9 270 and R9 270X for comparison. How close can the mid-range level GTX 750 Ti FTW come to the higher priced R9 270 series cards? Let’s find out.
Our synthetic tests show a pecking order that actually held true throughout our entire test suite. The EVGA GTX 750 Ti FTW had no trouble topping the R7 260 and R7 260X in all the tests. Once it was overclocked, it closed the gap substantially when compared to the R9 270 and R9 270X.
HWBot Heaven Results
3DMark Fire Strike Results
3DMark 11 Results
3DMark 11 Results
3DMark Vantage Results
The game benchmarks show the same pattern with the EVGA GTX 750 Ti FTW topping the R7 260 series cards handily. Of note here are the Bioshock Infinite results, where the EVGA GTX 750 Ti FTW actually topped the R9 270 at stock speed. Then, when overclocked, it topped the R9 270X just for good measure! The Battlefield 4 and Crysis 3 results also show this card holding very close to the R9 270 series cards.
Batman: Arkham Origin Results
Battlefield 4 Results
Bioshock Infinite Results
Crysis 3 Results
Crysis 3 Results
FFXIV: ARR Results
FFXIV: ARR Results
Grid 2 Results
Grid 2 Results
Metro: Last Light Results
If you were paying attention, you will have noticed that every game surpassed the 30 FPS threshold we call “playable”, except for Crysis 3 and Metro: Last Light. That’s some pretty impressive stuff for a card in this class. In the end, a pretty sweet showing here for the EVGA GTX 750 Ti FTW!
Power Consumption and Temperatures
With the aid of a Kill-A-Watt meter, I used HWBot Heaven and the Combined Test within 3DMark 11 to get the maximum power draw from the video card. I’ve said it before, and I’ll say it again, I’m amazed when I see how little power these modern PCs use. Even with the EVGA GTX 750 Ti FTW overclocked and under load, the total system draw still remained under 200 watts. When idle, the entire system used no more wattage than your standard 100 watt light bulb. Yea, amazing!
Power Consumption
Power Consumption
Equally impressive are the temperatures this card runs at. With temperature readings normalized to 25° C ambient, the card never even sniffed the threshold temperatures. While it’s true we didn’t have a lot of voltage manipulation at our disposal, it’s easy to see that the thermal improvements Maxwell GPUs bring forward do indeed work quite well. With temperature readings like these, there is no reason to take the fan off of auto control… even if overclocked. The ACX cooler performs quite admirably to say the least.
Temperature Readings
Pushing the Limits
I wasn’t able to get a whole lot more out of the card before stability issues arose, but I did manage a 3DMark Fire Strike run with an additional 15 MHz added to the GPU and 25 MHz added to the memory speed. This gave us just short of another 100 points added to our previous overclocked score.
evga_gtx750ti (55)
Conclusion
I must admit, I was thoroughly impressed with the EVGA GTX 750 Ti FTW from the moment I started working with it. From impressive overclocking to the great performing ACX cooler, everything worked terrific right out of the box. The improvements the Maxwell GPU bring are impressive, especially on the performance per watt front. EVGA has done a great job with their first implementation of a Maxwell based graphics card. The card is aesthetically pleasing and will fit into just about any PC application I can think of, which allows a good gaming experience to be brought to systems that couldn’t before handle the power demands.
Pricing on Maxwell based GPUs will run anywhere from $119 up to $169, depending on how much of a premium is put on partner card’s factory overclocks and proprietary coolers. Here is the breakdown of suggested reference design pricing NVIDIA passed along to us.
  • GTX 750 Reference – $119
  • GTX 750 Ti 1 GB Reference – $139
  • GTX 750 Ti 2 GB Reference – $149
As for the EVGA GTX 750 Ti FTW, it will be available for $169 MSRP. That means a $20 premium for the factory overclock and the ACX cooler, which is a bargain in my opinion. The Maxwell based GPUs should be available at e-tailers on launch day. While the price is slightly higher then the competing R7 260X, the performance gains easily make up the difference. To that end, I think the pricing lands right where it should.
The highest sales volume for video cards is the sub $200 market, and EVGA certainly has a very attractive offering in that category with the release of the GTX 750 Ti FTW. Price, performance, overclocking potential, and the latest Maxwell technologies… it’s all there! It’s a no brainer this time around – Overclockers Approved.
Overclockers_clear_approvedClick the stamp for an explanation of what this means.
Dino DeCesari (Lvcoyote)
About Dino DeCesari 230 Articles
Dino DeCesari was a pillar of the Overclockers.com community for over 13 years when he passed away suddenly in 2015. His legacy lives on through his hundreds of computer hardware reviews posted here. Dino spent time in the army as a Telecommunication Center Specialist and received a commendation medal. He had a successful 20+ year career in the automotive parts and technology industry, where he eventually bought and sold his own business. Once retired, he volunteered as tech support for a non-profit and his local school district.
Loading new replies...
Avatar of ivanlabrie
ivanlabrie
6,458 messages 0 likes
Do you know if there will be any 4gb versions of the card?
Can you do sli with these? (I want 4, or a multi gpu card equipped with them)
Performance per watt is incredible!
I'd love one/four :p
Also, can you try some yacoin mining using cudaminer? :D
Reply Like
Avatar of cullam3n
cullam3n
3,064 messages 0 likes
Thanks for the review, looks like an awesome budget card :thup:
How do I know you didn't read? :p
Reply Like
Avatar of Lvcoyote
Lvcoyote
Overclocked Moderator, Overclockers.com Lead Edito
1,473 messages 0 likes
No 4 GB versions and no SLI support.
Reply Like
ivanlabrie
I did read, but I'm at work, skipped to the overclocking part...(all that matters!)
Reply Like
Avatar of GTXJackBauer
GTXJackBauer
6,799 messages 0 likes
Thanks for the review! I might grab one or two of these.
Reply Like
Avatar of ATMINSIDE
ATMINSIDE
23,912 messages 406 likes
This makes me happy for the 800 series.
Apparently another review site broke into the ~1420MHz range with their 750Ti.
Massive OC potential on these.
Reply Like
ivanlabrie
And that whilst still keeping the gpu at 60-70w give or take!
Heads up: Kepler Bios Tweaking tool works with these...
https://www.dropbox.com/s/3sgcundg3jojhcw/Asus.GTX750Ti.2048.140113.rom
That's a tweaked bios for the Asus card with increased tdo limits and no throttling. :D
Reply Like
Avatar of TeknoBug
TeknoBug
436 messages 0 likes
The 750Ti has me interested for my HTPC FM2+ system for the low power consumption and still being able to play games casually on the TV.
And no there won't be a 4GB version, unless Nvidia wants to sell them to dumb consumers (128bit memory doesn't like anything over 2GB AFAIK).
Reply Like
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
76,637 messages 3,348 likes
If like means its too slow of a bus, sure. It can use it, but its pointless, really due to the bus.
Reply Like
ivanlabrie
It would boost my yacoin hashrate twofold lol...gimme 4gb Nvidia dammit
Reply Like
