- Thread Starter
- #21
I'd use the first one since it'll give a slight bump to the ram and CPU_NB.
I actually went further and did 220x20. Stress tested for 10 minutes without problems or any temperature increases(52-53)
Your voltage is going to jump around slightly.
That looks fine to me Ghost , we usually go for 2 hours but that OC should do you fine.
Package temp is the core temp and I'm not sure if it's tmpin 1 or 2 on that board but your OK. As for core there's still a bit of leeway, you'll be fine.
The max 61C temp was because I was running google chrome and some programs while prime95 was stress testing in the background. Durning the 2 hour test i left it idle and the max temp was 58C.
It's a shi tty case for low temperatures, because only the back and the left panel have holes for blowing air out. My PSU is also located on the top. I will have to open the case tomorrow and check how's the cooler and post a picture of the left panel removed.
