- May 3, 2011
- Thread Starter
- #81
My take is you have some kind of configuration issue with your pc. If you are running basically the same OS on the same brand and model of SSD your computers should boot in about the same time. I don't think the cpu would make a big difference in the boot times. Do you have your SSD plugged into a SATA3 port? As far as the cpu's I wouldn't expect to see any big difference in speed except for the 500 MHz clock differential. UNTIL you do something that would saturate your six core and the other two cores would utilized. That isn't something that happens very often for your typical computer user.
well, that could be possible.. I have noticed my boot takes more than 30 seconds. And yes, I have the ssd on sata 3 and when using the ssd benchmark I get over 400 MBs. I was thinking once I get the new mobo, I'll probably do a fresh Win 7 pro 64bit installation and see what happens from there.
