- Jan 12, 2012
Well if you still have the volatge set a 1.48125 Cpu V and look at Hwmonitor in Post #38 you're getting some pretty good voltage droop. The goal with the LLC is to have it compensate for the voltage droop without overshooting the set voltage by too much. If you adjust the Cpu LLC to where the voltage stays closer to the set voltage. You may find you'll be able to lower the set Cpu Voltage because when you were running prime the Highest your Voltage went was 1.476 V lowest 1.44 v. Some where in between is what you'll likely need to get it stable at 4.0 again, though it will take some playing around to find stability again.
