A few things we need at this point. Please create a signature such as myself, Blue and Mr T have. It helps us know what exactly is in the setup without having to go back to the first post. Second I'd like to know the exact motherboard you have, I know it's a M5A97 but would like to know exactly what we're dealing with.
As far as the drop in Voltage I'm with Mr T, that it's V Droop. Like I posted previously you may be able to take care of this with the LLC. Additionally you may want to put spot fans on the VRM section of the board. I have a M5A99X Evo board and on my board the Nb heatsink gets really hot.
Ok good it's one of the Better M5A97 boards 6+2 VRMOk I will put together a signature in the next couple hours. In the meantime here is a link to my MB.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
I also enabled the LLC which put my volts way up so I will drop that down and retest. It is way overcompensating currently.
As far as the LLC the goal is to have it set where it keeps the Voltage under load as close to the Set Voltage in the BIOS. Once you find a setting that keeps it as close to the Cpu V as it can. As I mentioned earlier, you may be able to lower the set voltage for the Cpu in the BIOS.
Signature works, if the board has Ultra high as a setting, I find it to be the most efficient one for LLC on my M5A99X evo.Will this signature work or do you need any other information?
Did you get a manual with that board? Near the back it'll tell you how in the BIOS section.
Looks like all you can do is set it to manual, then maybe other options will appear the manaual doesn't say much
I agree, if you can't find any other settings except what you mentioned then don't change a thing 5 hours of blend it is stable. Have fun with it.Dude, it looks like you're good to go.
You set it to enable, then your options for percentage show up.
'Enabled' should be re-labeled 'Manual'. Crappy Asus translators.
Hmmm......that's odd.It hasnt for me
You're pretty close to the top temperature wise, for a daily Oc you may want to stay put. If you're looking to just push then go right ahead.Thank you guys for all your help. I will see if i can figure out the bios llc issue and will let you know. Should I try pushing the clock at all to 4.1 or 4.2ghz or is it not worth it?
Is the board an EVO? I ask because I know the m5a97 (non EVO) has the same description in bios, but is on off or auto.
