- Jul 30, 2011
- NYC & FL
With the system Setup i have listed below...
What CPU cooler would you recommend for Overclocking and quiet as hell for a AMD Phenom II x6 1055T - 2.8GHz, 3.3Ghz Turbo Core??
Right now i have the stock cooler and not OC'd yet. Wanting to go as high as 3.0Ghz for this system. (Mentioned Here)
so ANY HELP, suggestions would greatly be appreciated. I'd like to go the not so cheap rout but not so expensive either. If i have to shell out a little bit that's fine by me.
I do a lot of Photoshop, Illustrator, Microsoft Expression Web (for web page coding), AutoDesk AutoCAD & Revit Architecture 2010. So my system would need to be able to kick a$$. I sometimes run these programs at the same time and get lag and or BSOD. I just want to tweak it, forget it and not have to worry about it ever.
Please Help, Thanks
Oorah!
__________________________________________________
MoBo: MSI 880GM-E43 (MS-7596 v1.3) Bios: AMI 7596v2B
CPU: AMD Phenom II x6 1055T (Thuban) - 2.8GHz, 3.3Ghz Turbo Core
RAM: G.Skill F3-12800CL9-2GBNQ (9,9,9,24,1T)
Video: HIS HD 5670 IceQ 1GB (128bit) GDDR5 PCIe v2.0 x16
HDD: (C:\) WD 500GB Sata & (D:\) WD 1TB Sata
ATAPI: HL-DT-ST DVDRAM GH24NS50 & SONY DVD RW DRU-540A
Sound: Onboard - ATI SB600 - High Definition Audio Controller
NIC: Onborad - Realtek 10/100/1000 Ethernet NIC
PSU: Extreme mn: RSY-645 450W P4 ATX 24PIN
Case: Novatech Galaxy III
OS: Windows XP SP3 x32bit
Please Help, Thanks
Oorah!
