What Prime 95 test are you using? I don't recall which tests favor which components but I do remember one is more weighted to giving the RAM a workout. And I would run it longer than one hour. For really stable, overnight with memtest is good. Unstable RAM can be flaky. It may do an hour of Prime95 no problem-then start throwing errors next boot.
That all looks good. I'd say a touch more of core voltage would fix you're instability problem in the 2 hr. Prime95 test. But if you can make almost two hours you probably won't have any issues in day to day computing.
Maybe. Yes, they are the same. Try it.
1.3375 is not excessive at all as long as you cooling keeps the package/core temps below about 55c or stress test load. Back in the day we used to run those things with more voltage than that 24/7. But like you, I always liked to be able to get the FSB up to where my RAM was running at full frequency. That is usually pretty doable.
Does the cooler have a PWM fan?
