Planning to upgrade to i7-3960x next week, or as soon as cpu/mb are available in the US.
What would be the best cooler to order? Noctua NH-D14? Anything else available with better performance?
Well as this will be a 6-core / 12 thread CPU you will need a beefy cooler to take it to say above 4.5 ghz i'd say, to get the most effective I would recommend a water cooled setup
Noctua (and no doubt most of the other makers) have some new coolers coming out very soon I believe.
They look to be specifically designed to handle LGA2011's new RAM layout also! I would hold off until they are are out if you are looking for a Noctua one.
Have you seen the 2011 CPUs? They are huge compared to 1366.
As an aside, I think somebody (preferably with wisdom) should develop a form factor for CPU heatsink mounts - it's only four holes for crying out loud, and is it really necessary to move them around a few millimeters every time a new platform comes out?
Unfortunately the chip doesn't ship with a stock cooler.
Although now according to the review the mount pattern is the same as 1366, only difference is that it has threads that may/may not work with the cooler in question.
