I posted what it displays when you press the Menu key and in addition to it I posted the link to it.
http://www.p3international.com/manuals/p4460_manual.pdf
It turns out you are supposed to press another button to get it to display watts.
I rebooted into Windows 8 and it shows 190 watts. I set it to go sleep mode in 1 minute and when it did go into sleep mode it read
8 watts.
Then I went to BIOS and set the settings back to what they were previous to how wagex kindly told me to change them.
Repeated the experiment and this time the sleep mode wattage was also
8 watts proving that BIOS settings had no effect on the sleep mode.
Originally I read the time since reset and I read KWH used over night:
In 8 hours 33 minutes, the computer+monitor system used up 1.12 KWH in sleep mode
It says it is drawing 8 watts in sleep mode but it said last night it drew 1.12 KWH in 8.5 hours of sleep mode.
I can repeat the same experiment tonight on Windows 10 and I can revert BIOS settings to what wagex said to.
What else would you suggest?
