Just because I use and suggest to others to try the auto-OC options (especially beginners) does not mean that I don't manually tune things. In the case of this FX-4170 though, the best really stable OC I have found is the one given to me by the auto-oc (202(3)x24). I have tried all of the options on both the CHV and the Sabertooth I have right now and the Sabertooth is the winner, but just barely. Manually I can get this FX-4170 to run @ 5.1 Ghz on the Sabertooth (not truly stable), and I have not been able to get the CHV to boot over 5 Ghz. More importantly (to me anyways) I am seeing slightly more fps in games with exactly the same settings with the Sabertooth. All of the reviews comparing these two mobos show a slight advantage to the CHV(that's why I bought it), but it is not working out that way for me. I don't know if maybe I got a crap CHV and a golden Sabertooth, but I am thinking the CHV is going to go back at this point. There is also an issue with the fancy audio deal on the CHV, a couple of older games I play locked up or crashed due to this.
@ Obsidus: I think the instability problems at high OCs you are experiencing are RAM related. I know you just built your rig, but if you decide to try another set of memory you can't go wrong with
Samsung 30 nm @ $47/8GB. This stuff is a dream come true for the OCr. It is really hard to get it to not boot , and I can get all 16 GB stable at above 2000 Mhz.
