- Dec 27, 2008
One more very important thing needs to be added to the list. You need to lower the HT Link frequency to start with. Stock is 2000 mhz and this particular parameter is very unforgiving. It doesn't like to be overclocked much at all on the model CPU you have. The adjustment is typically a mulitplier and the frequency will be a multiple of the HT Reference. Since the HT Reference is 200 mhz at stock, that means the stock multiplier is 10x. Lower the multiplier to 9x to start with. At a stock HT Reference frequency of 200 mhz a 9x multiplier would give you an HT Link frequency of 1800 mhz. In you overclocking process, try to keep this frequency between 1800 and 2000 mhz.
For instance, with a 9x multiplier and the HT Ref. at 210 the HT Link frequency will be 210x9 or 1890 mhz. Get it? You can see how it will grow as the HT Reference increases.
Personally, I would set the starting ram speed at 1066 and work on eventually getting your HT Ref. to 250 mhz. That would give you the full 1333 mhz ram speed which is also what the ICM is rated for, though it will usually tolerate some overclocking.
