- Dec 27, 2008
311, are you using the stock cooler that came with the CPU? I'm asking because I see your CPU temp is 45c in bios, meaning at idle without any load on and at stock frequencies and voltages. That is too high! We normally don't pay much attention to idle temps unless they are unusually high. Also, how hot is the room temp where the computer is? You live in Texas and it's probably boiling this time of year unless you use AC.
So here's what I need you to do. With everything at the frequencies and voltages you show in the recent bios pics, run Prime95 blend test for 20 minutes with HWMonitor open on the desktop. Then let me know what the minimum and maximum CPU vcore and the maximum and minimum CPU voltage is (it may show as one of the generic TMPINx lines so give me the numbers from all of those lines) and most importantly, the max and min core temps after that Prime85 run.
Otherwise, I see no bios settings that would suggest you can't run the HT Ref at 8 mhz over stock. So, I'm thinking it's a temp related problem.
