- Nov 25, 2001
- Niagara Falls, Ontario, Canada
Hi guys,
Just thought I'd report a successful mobile mod to a MIUCB 0407 Duron applebred, using a pencil.
Pencil used= Very sharp "DIXON No.2 / HB" yellow with eraser on the end. (Previously used to unlock a spitfire, most conductive pencil I found after ransacking the house and testing 10 or so with a multimeter)
Technique, scratched at the edges of the pits in the two middle L5s with a needle first, to make sure bridges were exposing some contact area and it wasn't oxidised from the lasering etc. Then just ground the tip of the pencil into the pits with a wiggle, and ran it over the top a few times, blowing excess graphite dust off as I did it.
result, Full mobile unlock, multis to 24X
This works on the mobile bridges because they are active low and it connects them to the ground plane, don't do this on bridges that are active high, it won't work, the pits need filling.
Further info. Chip is doing 2133Mhz right now at 1.85V 16x133, stepping isn't good (Compare JIUCB Tbreds in cpudatabase) Full load 44C in Toast with custom air cooling. Might get a couple hundred more Mhz after burnin.
regards,
Road Warrior
regards,
Road Warrior
