- Mar 3, 2012
- Thread Starter
- #61
I had a similar problem in a folding PC. It ran beautifully before, then one day it started getting a terrible lag with the mouse, even the keyboard was effected.
The problem was, the BIOS had a default setting to turn on PowerNow, and I had made it worse by changing some settings in the BIOS, (designed ironically to increase computational performance).
The answer for me was to go into the BIOS (hit the "del" key a few times as it's booting up), and hit the f9 key to load the optimal power options. Now go change your power options to disabled (which in my case, were left ON by my optimal power settings - a dreadful error by the BIOS creators).
Then hit f10 and save those settings, and exit. (These are for an AMI BIOS, yours may be different, of course).
If your problem was like mine, your lag problem will be completely gone.
Good luck!
My bios didn't have anything called powernow. I googled it and there was something similar that was called Cool n' Quiet, that I had in my bios. I turned it off but it didn't make any difference.
