- Apr 20, 2004
- JAX, Mississauna
almost all fx 6300 can do:
4.6ghz with 4.42-45
I bet they can do that speed at that Vcore.
4.6ghz with 4.42-45
4.2ghz with 1.33v
4.4ghz with 1.38v
4.5ghz with 1.40-42
4.6ghz with 1.42-45
4.7 or 4.8 with 1.47-50
I doubt that seriously. The cpu works as advertised does it not? Yes, I thought so. It just does not do the out of warranty overclocking like you think that it should. On a good motherboard, that cpu would probably act in a different manner entirely.Ben62884 said:seriously thinking maybe a bad cpu?
When the Vishera FX-8350 is not breaking records,there seems to be a sharp increase in temps at higher clocks for all these cpu's..For me,my 6300 runs hotter @ 4.5g.My temps increase 5-7c,but max load temp is 52C @ 4.5g
At 4.4 @ 1.3v seems to be the sweet spot. 18C-46C! I could back off on the voltage another .025v,and test @ 4.5g.Hopefully temps follow suit,if I can get it stable on lower volts.
http://www.neowin.net/news/amd-vishera-cpu-sets-a-world-record-867ghz-frequency
@ Wipeout. How to put up Sig at OCF.
New Shortcut method for putting a Signature with your system information following your every post so people can know what is in the case that they are trying to assist with. You can use something like what is shown in my signature as a good template of needed information Thank you.
Mmmmmm, nice! You're making me anxiously await the arrival of this new mobo. Hopefully I can get some numbers at least in the same range as you. This 4.3Ghz on 1.4 is irritating, not to mention the whacky LLC on this board... Setting vcore to 1.4, and I end up getting anywhere from 0.96-1.70!!
