What are the problems?! If I try a higher bus speed, 260 for example, even with increasing voltage, computer crash after enters windows (7 64 bit, pro). All you can see above is stable at auto voltage (wich is very good), the cinebench score is very high endeed, but, why not more? I know, it is a sin to eat to much. So, what should I do, let the actual situation or is possible to sin more then just 3375 MHz? The cooling is done with Schyte Ninja 3 (1040 grams), the MB chipset of MSI 990FXA is a very good one or is not sufficient? The goal with be at least 3800 MHz, so if somebody can explain what I did wrong or what should I do to UEFI bios settings of the MB to acheave this goal..I will be very thankfull.
I observed also other things, that the AMD Turbo function is useless, the turbo multiplier of 16x does not aply, and maximum multiplier remains 13,5 so the bus speed increasing is the only solution to OC the CPU. Olso I removed all settings wich prevents the OC, settings of MB on its own, and nothing, the same crash.
