- Aug 16, 2009
You're currently running 1.375 stock, and I would increase it by the smallest amount you're board will let you and keep ane eye on you're core temp, I just had a quick look at you're hwm pic and I don't know what's going on with you're boards temp sensors as there reading some crazy temps on max, I hope there false readings (I'm pretty sure they are) but if anyone knows thus board or has experience with it will know if they are unreliable, I'm using my phone to reply so if spelling and gramma are poor that's my excuse
As for board temp I would guess he has AI Suite or something similar installed which temds to give some pretty wicked temps. At least it did with my board when installed and disapeard as soon as I uninstalled it.
@krisxzx ..... if you are getting better temps with the asus cooler stick with it as it wont hurt. As for CPU volt ..... when you are in your bios navigate down to CPU Voltage and hit you + key 1 time ..... this will adjust your voltage by 1 increment. Keep in mind by adding voltage you will be adding heat and you dont have allot of headroom left.
