Lol stupid mobile phone posting
i think i got lucky with my board or more likely its going to melt alot sooner than i hope
Yes I see forums all over that say posted from mobile whatever but this forum does not do so. Humh?
I have seen one user in the AMD mobo section that did melt his M5A97 with FX processor and he admitted he expected it to do so since he was pushing it. But so far only one.
How many have moved up to the better boards in a year that come in here regular? Nearly two hands full now if counting is accurate. They just flat-out wanted more speed. They got it, but now without board and some real cooling.
There are always that one or two that do not 'fit' the mold, but I don't know of any that post in here regular and have setups that run over 4.5Ghz day in and day out that do not have at least $250.00 in there cooling. Priming at plus 5.0Ghz or so, takes serious Vcore and thus dang heavy duty cooling.
Bassnut, mandrake4565, Caddi Daddi, old brave, Johan45 and myself are some that I can think of easily and none of those but Johan45 are not running serious water cooling loops. As regards Johan45, he has tweaked the ever-loving crap out of his cooling to make it work. Point is none of the big numbers with FX processors are done with minimal cooling. Not at all.
Truth is that 4.2 or maybe 4.4Ghz is plenty on a Vishera processor. Now that said when I do my video editting, I jump to my stable 4.8Ghz speed setting because I can and it is faster than 4.4Ghz. Not a lot but some. I can do it so why not? So i do.
FX processors draw way too much power for the performance they give in return. Thus they run way too hot. Especially hot when pushed and voltage to the cpu is necessarily increased.
I am typing right now on an Intel rig running 8 cores in Hyper-Threading mode at 3.6Ghz I think it is and i just opened Open Hardware Monitor and my cpu core temps are 36c and the cooler is only a single 92mm Xigmatec cooler. That is a $30.00 cooler against the over $250.00 it takes for me to run over 4.5Ghz on my FX-8350. By the way this older Intel rig will do over 4.0Ghz P95 stable using this same cpu cooler. So how hot something runs is a definite consideration and something AMD should have fixed and not just made the dang cpu overclockable but still behind Intel in gaming because of IPC.
Crap too much rambling.
RGone...
