Why wouldn't it? Its the stock voltage. Sure its dynamic, but, it will show the stock voltage.Running off of default won't show the stock VID in CPUz.
for me the vids are current, cause they are jumping
so im a bit unsure to be honest, what to do next.
its jumping now from 1.359 - 1.376
Save your current profile in the BIOS before you reset everything. Running off of default won't show the stock VID in CPUz. You don't want the summary screen in HWinfo you'll want the sensors. Just a list of temps, volts etc.. It should be on that screen. What does the CPUID screen in AIDA show
Use offset not adaptive. Did you enter the additional turbo voltage? If so then don't. Just below that entry where it says offset voltage type in 0.1v we'll start there.
Do you still have windows set to performance?
If you want power savings then yes leave it on balanced.. Since you see what voltage you are getting now I'm assuming you'll need more offset to get to the stable voltage you had for your OC. Like setting .3v offset should get you to 1.35-1.36v in Windows right?
Check all the advanced CPU power settings and make sure they're on. Also check EPU? is enabled
C states and EIST
