Deleted member 117404
Guest
- Thread Starter
- #81
Check over your manual, I've gotta go boss is callin we got an emergency
Got adaptive mode working, i had to auto setting the SVID instead of disabled, i told u earlier i get qcode 35, but when i change disable svid to auto, it boots fine, clock goes up to 1.408 max and falls back to 0.784v when idle. so i think i found what i need.
Thank you very much for all youre support and i think i can continue fine tune the adaptive mode now. i can swithc between all power modes in windows without any bsod and i believe its stable at 1.408 cause when stresstesting earlier it never crashed when voltage was set on 1.392. This is awesome, finallly after many many hours, once more, big thanks to you Johan
EDIT;
Now im wondering if i can put my ripjaws up to 4000Mhz any advise were to start? XMP enabled on 3000 now.
