- Oct 29, 2010
- Loveland, CO, USA
Hello people,
Got the Sabertooth 990FX in for the upgrade from my CHIVE. This has been a pretty difficult upgrade as I've been lazy the past year or so and had to remember/re-learn my CHIVE setup. Of course, it didn't help much to take the M/B out before remembering I had forgot so much -- Sheesh!
Since I had everything except the 8 hard drives apart and out of the case, I decided to just do a temp setup with the CHIVE M/B and the new Thermaltake Water 2.0 Extreme outside the case. This way, I could look (and take pics) of my BIOS settings and test the new cooler against the H80 "Scream Machine" it was to replace. I have an abundance of screen grabs on the CHIVE setups, so I have all the relevant numbers to compare to -- Just didn't have BIOS settings on my 4.8 GHz setup.
Well, where to start... I guess the best way to say it is, the new cooler is pretty much junk in comparison to the modified H80 I already have. I had spent a few hours lapping in the CPU waterblock back when I first installed the H80. Gone though about 4 or 5 fan combos looking for the best CFM/cooling flow, worked out the best setup for installation in this Landboy Air case, and the only short fall was the screaming noise the Delta 6000 RPM/210 CFM fan would make on anything more then moderate CPU loads. It did cool adequately though, so I resolved to continue using the H80 with this upgrade. Sidebar here - Why in the world do all of these cheap CPU water coolers have pointed waterblocks? How hard would it be to have them machine lapped to a reasonably flat faced surface. I know the excuse they use for having a crown on the mating surface, but they must know the loss of thermal contact they cause makes these coolers way less effective then a flat surface would.
Having took all the pics I needed of the CHIVE BIOS, I did a shutdown and swapped out the CHIVE for the Sabertooth. Using the H80 cooler, I booted up and went into BIOS. Well, I've see pics of the UEFI BIOS, but never sat in front of one until now. It is quite a bit more attractive I suppose, but it is also more to consider it seems. I was able to put up my pics of the CHIVE BIOS on the second monitor using HDMI to my camera. As much as possible, I transposed the CHIVE BIOS settings to the Sabertooth. I made sure to use less volts on everything and a bit lower frequencies to get a reasonable chance for good boot. The board came up OK so I did a bit of testing the settings.
Working with CPU-Z, HWMonitor and Linx first, I did some moderate tweeks to BIOS to get stable passes in Linx. I then started Prime95, expecting it to run pretty well as I was on the low side of a working setup I had running on the CHIVE. Well, I was wrong. I couldn't even get it to run the first pass before getting a BSOD. I continued to work with BIOS settings and Prime95, but for the life of me it really doesn't want to run unless I am way below what would be normal for this CPU's performance levels. I not done yet, but I thought I post here and maybe some of you who have already setup the Sabertooth with a FX-8150 could chime in with your working BIOS settings. I need to be at or above 4.8 GHz to equal my CHIVE setup. Obviously, I would like to be above this, but I really need to at least match it, or this new motherboard will be going back along with the Thermaltake cooler which is going back regardless.
Thanks for any helps.
-Rodger
-Rodger
